Author Topic: Jamma Pinout Question  (Read 4263 times)
NiN^_^NiN
« on: May 05, 2004, 07:28:52 am »
I recently (last week end) got a cocktail cabinet and am maming it
i have a powersupply which outputs 5+ 5amp and 5- at 1amp
and 12+ and 12- at 1amp
Are these amp's ok to use on a jamma rig/harness etc?
i have a jamma connector i ripped out of my old cab and im just wondering if it is tomany AMPS for a jamma board?
im gonna hook up my 5" RGB lcd to the jamma wires so i wanna know if i can use this power supply??
sorry im a newbie at this more of a mamer not real arcade stuff.
SirPeale
  • Green Mountain Man
Re:Jamma Pinout Question
« Reply #1 on: May 05, 2004, 10:17:59 am »
I assume you're talking about a PC power supply, and no an arcade PS.
People have used PC PSs on arcade boards, but I'm not sure how it's done (other than the raw wiring).
NiN^_^NiN
« Reply #2 on: May 05, 2004, 10:30:50 am »
No a real arcade power supply it outputs 5amp on 5v + then 1amp on 5v - 12v + and 12v -
what is the max amperage/milliamps the jamma board usually has?
i wanna make sure its ok to use this arcade powersupply i got it out of my cocktail it replaced the old power supply that was in the cab then i got it a few now so the powersupply is in a black box where u wrap the wire around the screw then tighten it.
so is this PSU ok? to many amps?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: May 05, 2004, 10:36:02 am »
Jamma game boards don't use a "-12 volt". Most games need at least 2 amps on the "+ 12 volt" line. Also, the "+5 volt" line needs to be a minimum of 11 amps for most Jamma game boards. Your power supply is too wimpy for the job.
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #4 on: May 05, 2004, 04:12:24 pm »
Shouldn't it be in the JAMMA specification, which can't be too hard to fine.
Or you could just stick an ameter across your power supply.
I thought +12 and +5 was pretty standard anyway.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: May 05, 2004, 06:14:36 pm »
Jamma specifications/standards are on the AMOA website: www.amoa.com/policies/industry/
There's no rule that says the minimum current the supply should put out, but speaking as an expert, I'd want a minimum rating of 11 amps from the power supply's "+5 volt" line. Jamma games do not use a "-12 volt". They do however use "+12 volts for sound (on board amplifier chips), 12 volt coin counting meters, and sometimes 12 volt coin door lights. You need at least 2 amps (preferably 3) on the "+12 volt"  line.
Many Jamma games tell you in their manuals what current ratings the power supply should have for the particular game board. If you connect a power supply too small for the job it may work for a few minutes then crap out from being overloaded. You need headroom on the power ratings.
NiN^_^NiN
« Reply #6 on: May 06, 2004, 03:01:27 am »
Well i only am making a Super Gun
wanted to know if it was strong enough as it doesnt have any specs on the amperage output from where i looked.
