Author Topic: ultrastyle 1.66 Beta available  (Read 1257 times)
ultrastyle
  • Last login:October 20, 2023, 09:52:29 pm
    • ultrastyle MAME Front-end
« on: April 30, 2004, 07:14:19 pm »
These are all of the updates sinceb I last posted to the board.
www.mameworld.net/ultrastyle
BETA 1.66 Released 4.30.04
Fixed:
- In ultraconfig, saving the category.txt leaves out information, causing the file to get smaller every time you save it (I take full responsibility)
- The roms were set to sort by real name, and they would sort ok, but now they are sorting 100% properly.
Added:
- You may now select startup mode for the wheel, the choices are: All Games, Favorites, Filter Wheel, or Any Sub-Category
  * If filtering is off, the only choice is All Games. If you don't have a Favorites.ini, Favorites is not a choice.
BETA 1.61 Released 4.29.04
Fixed:
- RGB Colors for the Text under the 3D screen objects were not reporting correctly.
- choosing up/down a letter was still connected to rom name, now connected to real name
BETA 1.6 Released 4.29.04
Changed:
- the games are now sorted by the game's actual name instead of the rom's name.
- Some radio buttons in ultraconfig have been changed to drop down lists
Fixed:
- the catlist sort in catconfig was inadvertently leaving out the first game on the list
- the checking off of a category to not show on the filter wheel was removing the next 2 categories as well
- mouse input is now much less sensitive
Added:
- when on the filter wheel, you can now see how many games in a sub category without going into it.
- there are now 2 choices for cube size: small, which was the previous standard, and big, the new size
- an optional global command line parameter is now tacked on to the end of the execution string
 Chris
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Re:ultrastyle 1.66 Beta available
« Reply #1 on: April 30, 2004, 11:40:29 pm »
Man, you really crank out the updates. This thing is starting to look really good. Maybe its time for a sticky up top with the other FE contenders?
Keep it up...your FE is comming soon to a cab near me.  ;)
All Your Base Are Belong To Us!
ultrastyle
« Reply #2 on: May 01, 2004, 02:20:36 am »
Spaced,
 Thanks! I used the catlist to add filtering, thanks for the info. Actually I quit my job last month, so doing this is keeping me sane. I am doing my best to add things people request. I have got a few skins and soundpacks donated as well. It's all coming along. If only I could do it for a living..
 Chris
