Author Topic: Mounting my monitor (urgent!)  (Read 1269 times)
Ceifeirot
  • Last login:September 24, 2005, 03:58:56 pm
« on: April 29, 2004, 12:09:12 am »
Hello,
Sorry for the urgent sign, I've got basically everything else done with my MAME cabinet (to have it in working condition, not finished condition) except for having the PC monitor mounted inside. And this is for a school project that's due very soon. (my host family from Japan is coming for the next few days and I'd rather not do work while they're here)
How do I mount it?
I have a 19" PC monitor that I took the stand off of. I'd rather not screw something into the monitor. Is there a good way to just have something holding the monitor in from the back maybe? Some kind of L-shaped brace?
The monitor sticks out a couple inches in the back. Also, the wood it's sitting on is angled so much that the monitor just starts to slip backwards if I leave it in there, so I definitely need something holding it in.
Thank you!!
SaiNRuB
  • Last login:November 26, 2024, 07:30:53 pm
  • Pluck your magic twanger, Froggy!
Re:Mounting my monitor (urgent!)
« Reply #1 on: April 29, 2004, 01:30:47 am »
Heres some info for just that from OSCAR
How to install a PC monitor in a cab (photos!)
Good Luck
SaiNRuB
« Reply #2 on: April 29, 2004, 01:35:32 am »
If you prefer the shelf method you must be sure that all bracing and the shelf be super secure and mounted evenly with the rest of the cabinet to prevent any lopsidedness. Its a very common procedure, me myself i havent mounted a pc monitor but if i did i would prefer OSCARS method.
garyh
  • Last login:January 26, 2011, 02:30:17 am
  • If God rides a Harley then the devil rides an LC.
« Reply #3 on: April 29, 2004, 08:05:16 am »
I mounted mine like the Oscar example but just used wood offcuts rather than making metal brackets. Worked a treat.
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« Reply #4 on: April 29, 2004, 08:27:04 am »
Everytime I turn around I stumble on another amazing OSCAR tutorial.  Thanks OSCAR!
Ceifeirot
« Reply #5 on: April 29, 2004, 08:32:00 am »
Wow, how did the search function miss that?
I looked through EVERYTHING containing the word "mount" and didn't see that, and several other searches
This forum really needs a better search function :(
THanks for the help!
hyiu
    • www
« Reply #6 on: April 29, 2004, 10:38:11 am »
how slanted is the monitor going to be after its in your cab ??
I also have "sort of" mounted a monitor into a standard cab... (a 19 in pc monitor...)
I bought a monitor.... and took off the plastic cover...
then I found out that the front can't be taken off easily... and inside the plastic back cover, there's a metal cover right under....
since what I read from this board is.... monitor has more dangerous parts inside (even when unplugged...) and I don't want to take a chance, I simply traced the edge, and let the monitor sit on a board leaning on the cab... (and its good and tight and doesn't wobble....)
http://geocities.com/hyiu/pics/Arcade/Cab_and_Stick/
« Last Edit: April 29, 2004, 10:40:28 am by hyiu »
