Author Topic: Broken Wires at Quick Connect  (Read 1250 times)
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« on: April 25, 2004, 07:12:01 pm »
Hi All,
I'm not sure if any of you have this problem but it has to do with the wires breaking off at the Quick connects. It's happened a couple of times now. I am using .22 guage stranded wires (7 wires per strand) and .167 quick disconnects. I crimped and soldred the ends (belt and suspender approach). I have to swing the control panel up to access the keyboard which exposes the wiring. Are the wires breaking because I crimped too hard? Is it the solder joints making the connect connection weaker? Is anyone using a different approach tpo wiring? I think the next control panel I make will be bolted down with a slide out shelf for the keyboard instaead. Maybe this will help. Any idas would be appreciated.
Cheers!
Garry
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
Re:Broken Wires at Quick Connect
« Reply #1 on: April 25, 2004, 07:58:53 pm »
I don't know the specifics of your situation but over crimping can cause wires to break. However, if the wires flex at the connectors each time you open the panel that could also cause your problem. Try to fasten the wires to your control panel with a cable clamp. This will stop the flexing at the connectors. Soldering a crimped connector is not necessary.
