Author Topic: Controls.dat - Quick and Dirty  (Read 2165 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: April 24, 2004, 01:09:32 pm »
Where can I get the Controls.Dat file?
Also, how about the Controls.xml file?
TalkingOctopus
    • My Arcade
chrisindfw
  • I drank what?
Re:Controls.dat - Quick and Dirty
« Reply #2 on: April 24, 2004, 03:38:02 pm »
That only has 495 games in it. Is there a file that tells the inputs of each game?
TalkingOctopus
    • My Arcade
« Reply #3 on: April 24, 2004, 04:41:34 pm »
The controls.dat is still a work in progress.  You might want to check out the sort info tool.  It may have some of the information you are looing for.
http://hem.passagen.se/robert.palmqvist/Downloads/downloads.html
krick
  • Gotta have blue hair.
« Reply #4 on: April 26, 2004, 12:41:07 am »
What is "controls.dat" for?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: April 26, 2004, 12:51:57 am »
It's in the FAQ for controls.dat.  Documenting the controls used by games in mame.
ok, 505 game directly supported, 1044 indirectly supported.
chris, the xml file is broken, I am going to try and fix it soon.  Just delete the offending chars that are causing the probs.
« Last Edit: April 26, 2004, 12:53:44 am by SirPoonga »
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: April 26, 2004, 06:52:16 am »
Like Sir Poonga said, basically, you fire up a game in MAME, you can tell it uses four buttons, but what do they do?  That's what you use controls.dat for.
Also, eventually, it should be incorporated into a frontend, so that if you have an image of your CP and label locations for each button, the frontend will tell you what each button does.
