Author Topic: Joystick Hole Size  (Read 2505 times)
SuperRabbit0
  • Last login:July 07, 2006, 08:53:30 am
Joystick Hole Size
« on: April 23, 2004, 12:24:15 am »
I am reaching for the simplest question of all time but I'll be damned if I can find this here or on the Ultimarc site.
I am installing a T-Stick balltop in my panel.  What size hole do I drill for the joystick shaft?
TalkingOctopus
    • My Arcade
Re:Joystick Hole Size
« Reply #1 on: April 23, 2004, 01:01:16 am »
A 1 1/8" hole should be fine.
exian
  • Last login:February 01, 2005, 02:04:05 am
  • Game NOT Over
    • MAME Fighter Alpha
« Reply #2 on: April 23, 2004, 02:57:54 am »
I just made a test Control Panel and cut the hole using 1 1/8" Spade Bit using my Electric Drill. Its perfect for the shaft on the T-Stiks and its the same size hole for the Buttons so you don't have to swap Spade Bits, just keep on drilling.  ;)
brianoneill
  • Last login:January 27, 2017, 04:44:59 pm
« Reply #3 on: April 23, 2004, 04:20:08 am »
I was just about to ask a very similar question !
I was on happ controls website looking at the ultimate joy and wondering what size to drill.
Should it be 1 1/8" or 1.25" ?
Cheers.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #4 on: April 23, 2004, 07:34:41 am »
The T-stick has a 33mm wide top (at least that's what it says in the diagram, mine is 31mm). If you drill a 1 1/8" hole you'll need to take the stick apart for mounting.
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #5 on: April 23, 2004, 11:43:54 am »
I just measured, but the stick standard only moves less than 20mm or about 3/4". The balltop only 14mm (9/16").
So, if you are planning to take the stick apart you can driller a much smaller hole. Especially if you are hiding those dust covers it will look a lot better when the hole is smaller.
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #6 on: April 23, 2004, 11:51:45 am »
Also the dust washer on the ball top is much smaller then the regular tstick handle.  If you are using a ball top make sure you drill a smaller hole or else the washer will not cover it all.
