Author Topic: Daphne - Sound initialization failed! - Help  (Read 6354 times)
jec993
  • Last login:November 03, 2006, 02:53:42 pm
  • programmer
« on: April 17, 2004, 09:49:48 pm »
i know some of you are able to run Daphne and i was hoping you could help me out.
i'm trying to get dragons lair to run properly and it keeps telling me "Sound initialization failed!". That's as informative as it gets, both on the screen and in the daphne_log.txt.
this is with launching dragons lair with DaphneLoader. i'll worry about getting it to run with my proper frontend later.
if i disable sound in daphneloader, the game runs and plays fine, just without sound.
any of you guys got any tips and pointers on what i need to change to get the sound to work?
i've searched the daphne forums and came up empty.
thanks,
-jimC
btoddkelley
  • Last login:October 20, 2013, 04:52:05 pm
Re:Daphne - Sound initialization failed! - Help
« Reply #1 on: April 18, 2004, 12:22:58 am »
That will happen if you do not have the samples in the sound folder. Make sure they are there, you should have got them in the downloaded zip. Which version are you running?
Todd
For it is not enough to have a good mind, rather the main thing is to apply it well.
- Descartes
jec993
  • programmer
« Reply #2 on: April 18, 2004, 08:44:40 am »
i'm running v0.99.6
my daphne\sound directory contains the following samples from the download. am i missing other sounds?
ab_alarm1.wav
ab_alarm2.wav
ab_alarm3.wav
ab_alarm4.wav
ab_enemy.wav
ab_fire.wav
ab_ship.wav
bl_shot.wav
cliff_correct.wav
cliff_startup.wav
cliff_wrong.wav
dl_accept.wav
dl_buzz.wav
dl_credit.wav
dl2_bad.wav
dl2_coin1.wav
dl2_coin2.wav
dl2_coin3.wav
dl2_coin4.wav
dl2_error.wav
dl2_good.wav
dl2_tic.wav
dl2_toc.wav
dl2_warble.wav
dl2_warn.wav
esh_beep.wav
f_accept.wav
f_background.wav
f_button1.wav
f_button2.wav
f_click.wav
f_click2.wav
f_dpadMove.wav
f_gameSelect.wav
f_startGame.wav
f_woosh.wav
gr_alarm1.wav
gr_alarm2.wav
gr_alarm3.wav
gr_alarm4.wav
gr_attack.wav
gr_cannon.wav
gr_fire.wav
gr_mineon.wav
saveme.wav
sd_coin.wav
sd_fail.wav
sd_succeed.wav
sda_success_hi.wav
sda_success_lo.wav
thanks,
-jimC
btoddkelley
« Reply #3 on: April 18, 2004, 06:32:07 pm »
Are you sure it is 99.6? You have the samples for dragons lair 2, which are only in the CVS. Also, this was a problem for DL2 in the CVS until recently. Is it Dragons lair you are trying to run or DL2?
- Descartes
jec993
  • programmer
« Reply #4 on: April 18, 2004, 07:18:24 pm »
THANK YOU!
i am running 0.99.6 but somehow i had sounds that were from a different (newer?) version. i have no memory of where those other samples came from.
i just renamed my sounds directory, copied the sounds dir out of the daphne zip and things are now running great.
just curious, is there a running changelog for what is changed from 0.99.6 and what you can get from a pull from CVS?
again, thank you very much for your help.
-jimC
