Author Topic: Anyone know what monitor this is?  (Read 2273 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: April 17, 2004, 03:41:00 pm »
hi
i've just bought this arcade monitor on ebay (please see attached pic)
Does anyone know what make/model monitor it might be?
i know this is probably a long shot (i figure most monitors all look alike inside).
i am too impatient waiting for the seller to get back to me with make and model details. apparantly it came out of a working jamma cabinet and is descibed as "working as new".
sorry if this is another stupid question   ::)
i want to look up the specs on it and check if it need to get an isolation transformer.
Anyone know of anywhere to get a I.T. in the UK? (if it turns out that i need one)
cheers
- richard
« Last Edit: April 17, 2004, 05:49:11 pm by rchadd »
Ken Layton
  • Guru
  • Technician
Re:Anyone know what monitor this is?
« Reply #1 on: April 17, 2004, 11:50:30 pm »
Looks like a Wells-Gardner 19K4900 (a.k.a. the 4900 series).
rchadd
  • Made in Cornwall
« Reply #2 on: April 18, 2004, 08:15:07 am »
is that any good?
will it need an isolation transformer?
cheers
- richard
« Last Edit: April 18, 2004, 08:16:03 am by rchadd »
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 18, 2004, 11:43:08 am »
Yes, it's ok and yes it REQUIRES an isolation transformer.
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« Reply #4 on: April 18, 2004, 06:06:49 pm »
You should always use an isolation transformer even if the manufacturer says you don't need one. It's just cheap insurance.
www.wolfelectronics.ca
Cap Kits for Canadians!
rchadd
  • Made in Cornwall
Isolating Transformer
« Reply #5 on: April 18, 2004, 06:30:41 pm »
bob roberts mentions how to wire one up here http://www.dameon.net/BBBB/buildit.html
it seems pretty straight forward.
what spec isolation transformer i should be ask/looking for? or are they generic for all monitors (as i am in the UK it should be 240v)
what are their approximate size?
where's best place to get one (i'm in the UK)?
will i need the power filter also, or will unfiltered mains to the monitor be ok?
i will have a ATX PSU also to power the motherboard.
i hope this will all fit inside the cocktail cabinet  :-\
Also is there a way to power off the monitor when the PC is shutdown?
cheers
- richard
Ken Layton
  • Guru
  • Technician
« Reply #6 on: April 19, 2004, 12:14:48 am »
Go to www.happcontrols.com and click on their contact info. They have a UK branch office with quite a good stock of everything. They will have an isolation transformer for UK use.
rchadd
  • Made in Cornwall
« Reply #7 on: April 19, 2004, 07:11:02 am »
i saw that they only had a 110v use transformer on their webpage, but i'll give them a call anyway.
what about the filter, do you think it is neccessary?
Ken Layton
  • Guru
  • Technician
« Reply #8 on: April 19, 2004, 10:18:57 am »
The monitor does not normally use an external power filter. Usually the monitor's main circuit board already has a small power line filter in it. Your monitor won't need one, but it will need the isolation transformer. Ring Happs' UK office and talk to them.
