Author Topic: Mamewah - permission denied error  (Read 1898 times)
babaganoosh
  • Last login:April 28, 2004, 11:51:35 am
« on: April 08, 2004, 08:40:53 am »
I am new to MAME, please forgive me if these things are obvious....
I am running Mamewah on a win 98 machine.  How are you supposed to shut down the machine gracefully with that as the front end?  Break out and go to windows?
If my kids shut the machine off with the power switch or if the machine crashes, the next time you go into mamewah and try to run a game, you get an error that 'permission denied'. I reinstall mamewah, run that extra mamewah setup app and then you're good to go.  but there has to be an easier way?
Re:Mamewah - permission denied error
« Reply #1 on: April 11, 2004, 10:52:50 am »
When you exit using the menu you get the option to 'Exit & Shut Down'.  You can also set this as the 'Default Exit Option' (in Misc Options) so that hitting Escape (remappable) shuts down :)
babaganoosh
« Reply #2 on: April 18, 2004, 05:06:19 pm »
THanks for that tip on how to shut iut down properly, but I just had that same problem - the power went out this AM and now I get a permission error  when I try to run a game
« Reply #3 on: April 18, 2004, 07:16:10 pm »
Try this:
Make a batch file which does something like (substitute your mame path etc.):
c:
cd\mame
mame > temp
exit
Then run this batch file before MAMEWAH for the first time after boot-up.
I think that might get around the problem :)
