Author Topic: Need some help: Kinkos, vinyl, color correction.  (Read 1487 times)
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« on: April 05, 2004, 09:58:00 pm »
I'm working on some artwork for my control panel underlay, that will be printed at Kinkos on indoor vinyl, and I'm having some trouble with the color. I had a couple of proofs printed before I bite the bullet and get the whole thing printed.
 The top two images are from the file I handed them, the next two were scanned from the indoor vinyl proof, and bottom two were scanned from their laser proof on paper.
The laser proof is much closer to how I'd like the final color, but still not perfect. How should the file be tweaked to at least help with the final results?
mahuti
Re:Need some help: Kinkos, vinyl, color correction.
« Reply #1 on: April 05, 2004, 11:40:30 pm »
I would suggest asking them. Ask to speak with the person who has worked there the longest, or has the most experience with color correction & accuracy.
Color correction can be a very difficult & expensive problem. There are multiple factors.
1. The colorspace you are working in,
2. The paper you are outputtin to
3. The type of machine doing the printing.
4. The ink used.
Purples & blues are absolutely & consistently hard to correct, and very hard to get accurate.
The only suggestion I would make is to convert your art to CMYK. Almost all printers work in CMYK, rather than RGB. You might try to darken the image up a little bit.
Without having a competent person available at Kinko's there will be some difficulties.
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
« Reply #2 on: April 15, 2004, 10:59:05 pm »
Not promising speed but if you send me the file I would like to see what I could do with my machine.
