Author Topic: Wanted: Black or Red Dust Washer for T-Stik  (Read 1429 times)
maraxle
« on: April 04, 2004, 08:03:17 pm »
Hi.  I recently got a T-Stik Plus with the red ball-top.  Unfortunately, the dust washer that comes with the ball-tops (you know, the little ring around the base of the joystick) is smaller than the ones that come with the regular joystick, so if I push really hard in a particular direction, I can see the edge of the drilled hole.  The best way I can think of to remedy this would be to stick another dust washer that's bigger under the current one.  I would like two red or two black ones if anyone has some extras lying around.  Thanks in advance!
19rjs99
  • Last login:January 30, 2019, 08:31:31 pm
Re:Wanted: Black or Red Dust Washer for T-Stik
« Reply #1 on: April 04, 2004, 08:26:48 pm »
Make your own with left over Plexi. Use a hole saw for your drill in any size you want. Run it in reverse to cut the plexi and then sand the edges. Paint them any color you want. I would use the new Fusion spray paint for plastic as it will not chip off. Or be as creative as you want.
crashwg
« Reply #2 on: April 04, 2004, 10:18:38 pm »
How do you plan to get the dust washer past the metal ring on the stick?
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
maraxle
« Reply #3 on: April 04, 2004, 11:13:07 pm »
Not a bad idea!
Since I'll just put it under the other dust washer (making a layered effect), I can make the hole slightly bigger.
« Last Edit: April 04, 2004, 11:13:55 pm by maraxle »
