Author Topic: MameWah & X-Arcade  (Read 2397 times)
MameMe
  • Last login:June 08, 2005, 06:45:25 am
MameWah & X-Arcade
« on: March 30, 2004, 08:40:48 am »
Is there a readme that will show me how to setup my x-arcade controller in Mamewah?  I've searched Google with no luck.
Re:MameWah & X-Arcade
« Reply #1 on: March 31, 2004, 06:02:04 am »
The default settings should work OK with the X-Arcade...
If you mean in MAME then you need to set your ctrlr to 'xarcade' in your mame ini file.
MameMe
« Reply #2 on: March 31, 2004, 11:46:02 am »
I haven't changed my Mamewah settings.  The x-arcade controller DOES work with Mame32, but I don't like the front-end of mame32.  Hence I am tyingto use mamewah.
I have the normal mame (not mame32) working great with mamewah, but my x-arcade controller does not work in mamewah.
« Reply #3 on: March 31, 2004, 04:11:08 pm »
Ahh, it could be the Num Lock is to blame...I'm not sure but if the X-Arcade is like the HotRod and uses the num. pad 'cursors' then it will be picky about whether the num. lock - it should be turned off.
Hit P2 Start to see if the menu pops up - this should confirm that MAMEWAH is receiving the input from the X-Arcade...
MameMe
« Reply #4 on: April 04, 2004, 09:32:13 am »
I only have a x-arcade solo so I don't have a P2 button.
But..I opened notepad.exe and I noticed that my buttons are producing output.  For example my left white button located on the side of the x-arcade spits out the number 3.  The right button spits out number 4.  My white player 1 start button spits out number 1.
The controller works fine in Mame32, but it does not work with mame commandline  & mamewah.
Please help, I really want to use Mamewah as a front end.
« Reply #5 on: April 05, 2004, 06:07:44 am »
Sounds like your X-Arcade is working then...try what I said (using it in MAMEWAH) but use '2' on your keyboard to bring the menu up.  As I say the default MAMEWAH config will work with X-Arcade (you might want to remap P2 Start for yours, go into Control Options > Customise Controls).
You need to set your controller (ctrlr) to 'xarcade' in your MAME ini file for it to work correctly in MAME.  Read the MAME docs and http://www.mameworld.net/easyemu/ ...
MameMe
« Reply #6 on: April 05, 2004, 12:16:56 pm »
My solution:
Originally I was trying to use mame & mamewah and that's why I was having problems.  I guess I didn't know how to configure the mame ini files or something.  So I gave up that configuration.
So...I went with mame32 & Mamewah.  I didn't think mamewah would work with mame32, but it does!  Wahoo!  Now I can configure mame32 ini files under the /ctrl/ini files for my x-arcade.  Works for me.
Anyone else use mame32 & mamewah?
« Reply #7 on: April 05, 2004, 12:21:39 pm »
My solution:
So your X-Arcade does work with MAMEWAH now??  If I may say so you were a little confusing about what the problem was...changing to MAME32 would not affect how the X-Arcade works with MAMEWAH itself...
A few people use MAME32, although I do not usually recommend it.  If it all works OK for you then there is no real reason to change tho :)
MameMe
« Reply #8 on: April 06, 2004, 09:49:20 am »
I have no idea why telling mamewah to use mame32 instead of mame corrected the problem.  I'm assuming its because mame32 has an option under "Default Game Options"-"Controllers" to choose an x-arcade controller.
So why do you recommend mame and not mame32?
