Author Topic: How does one install T-nuts?  (Read 2779 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: March 29, 2004, 06:34:17 pm »
I think I'm going to use some big T-nuts to attach my side panels to the frame.  How does one install them, though?  Do I just drill the hole for the shaft, countersink a tiny bit for the base and then use a hammer to pound those little spikies in?  It's the spikies that really have me confused.  They look too big to try to pull in just by screwing a bolt in the other side like I would to pull the squre part of a carriage bolt into the hole.
edit: spelling
« Last Edit: March 29, 2004, 11:56:41 pm by shmokes »
Best Kid iPad Apps
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
Re:How does one install T-nuts?
« Reply #1 on: March 29, 2004, 06:45:34 pm »
That's exactly what I did.
saint ganked my avatar.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: March 29, 2004, 07:07:59 pm »
Yes, they need to be pounded in with a hammer.
shmokes
    • Jake Moses
« Reply #3 on: March 29, 2004, 11:58:08 pm »
Cool, thanks guys.  It looked like that would be the way to do it, but I spent WAY too long shaping those side panels to screw them up doing something stupid.
Best Kid iPad Apps
Tailgunner
« Reply #4 on: March 30, 2004, 12:39:54 am »
Hammering them in works for the spiked T-nuts, though given a choice I buy the screw in type instead. Those have three holes in the backing flange and attach to the panel with wood screws.
krick
  • Gotta have blue hair.
« Reply #5 on: March 30, 2004, 12:52:24 am »
Do you mean these...
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
shmokes
    • Jake Moses
« Reply #6 on: March 30, 2004, 01:39:29 am »
Yes and no.  Those aren't the type of Tee-nuts I'm using:
Best Kid iPad Apps
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: March 30, 2004, 06:48:37 am »
Krick,
I think you have those mounted upside down.
I only mention this because I made a similar mistake on a project - You want the T-Nut's mouted on the far side (relative to the bolt) of the panel that they are going in, so the bolt pulls the panel tight.
I mounted some to the near side of the panel and the bolt easily pulled the T-nut loose.
FWIW!
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
« Reply #8 on: March 30, 2004, 08:55:12 am »
I used 5/8" MDF on my CP.
For the t-nuts (the spikey kind), I first drilled the spotface using a forstner bit, and then the through hole using a standard twist drill.
The bolts were then used to pull the t-nuts into place. seating them nicely below flush.
Hammering them into place may be necessary if you're using plywood or similar.
%$#@!&* machine took my quarter!
krick
« Reply #9 on: March 30, 2004, 11:30:49 am »
Krick,
FWIW!
Oh, that's not my control panel.  I was just posting the picture as a reference.  I found it on some guys website where he's making a subwoofer...
http://lonestar.texas.net/~bdub/subwoofer/
Hantarex Polo 15KHz
