Author Topic: How to mount joysticks  (Read 1696 times)
krick
  • Gotta have blue hair.
« on: March 26, 2004, 11:01:48 pm »
I know this has probably been discussed to death but I can't seem to find any really good threads on the subject.
I'm making a new control panel.  My cab has a 3/4" MDF control panel.  The current joysticks look very much like Happ Competition sticks.  I don't see any identification on them so I'm not sure.  Anyway, the're just bolted to the underside of the panel using carriage bolts through the top of the MDF.  There's a layer of plexi on top of the control panel.  I don't think I will use plexi on my new panel.
I plan on getting new sticks, possibly the T-Stick Plus model from Ultimarc.  From what I've read, I'll need to rout out a depression on the underside of the panel so that the thickness is only 1/2".
Can I just bolt them down with carriage bolts?  Will 1/2" MDF be strong enough?
Should I be using a metal plate like this?...
http://www.dameon.net/BBBB/joyplate2.jpg
I saw that some people were able to attach joysticks without screw heads showing.  I would much rather have this than carriage bolts. What hardware is used to do this?  Where do I get it/them?  Again, will 1/2" of MDF be strong enough?
Any tips and tricks that people can impart will be greatly appreciated.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
GGKoul
  • Cheesecake Apprentice
Re:How to mount joysticks
« Reply #1 on: March 26, 2004, 11:51:05 pm »
Oh my god!!!
This is the 3rd post about mounting joysticks in the last 24 hrs!!
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=17537
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=17412
Yes a 1/2 inch of MDF will support the joysticks
« Last Edit: March 26, 2004, 11:52:20 pm by GGKoul »
krick
« Reply #2 on: March 27, 2004, 12:02:36 am »
Oh my god!!!
Yeah.  Well, the first thread went off on a tangent about mounting a J-PAC. And the second turned into a religious debate about using 1/2" plywood vs 3/4" MDF.
What I really need is information about the hardware involved and what my options are.
Hantarex Polo 15KHz
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #3 on: March 27, 2004, 12:38:24 am »
Tee-nuts - you would screw in the joysticks from the bottom of the CP using them.  I would imagine a good hardware store would have them, but I've never looked.
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #4 on: March 27, 2004, 01:08:47 am »
Home Depot has T-Nuts. (If there is one near you)
