Author Topic: Problems with VPLaunch & other Wrappers  (Read 3200 times)
BobBorakovitz
  • Last login:January 17, 2023, 08:09:10 pm
« on: March 26, 2004, 10:21:50 pm »
I'm having a problem loading anything in VPLaunch or the
command line wrapper.  The screen goes blank and doesn't
let me do anything.  I have tried everything, I've searched
message boards everywhere and google many times, but
found no good answers yet.  I'm hoping I find the golden egg here :)  I've tried manually also, in VPLaunch2.exe there's a menu that pops up and displays my tables, if I double click on the table it should load it up, right? The
screen just goes black and I can't do anything.  I dunno.
I think they were made by Howard Castro, but I'm not sure, there was no documentation.
If someone could help me, then thanx  ;D
BobBorakovitz
Re:Problems with VPLaunch & other Wrappers
« Reply #1 on: March 27, 2004, 01:28:43 am »
ok, on the VPLaunch front:
I've found someone else who has the same problem:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=36264&page=&view=&sb=5&o=&vc=1
I reinstalled Visual Pinball and VPinMAME
I updated to the current DirectX
no go on either....but....
Command Line Launcher:
I'm trying to get it to work with Handy (Atari Lynx Emulator) and when I use it normally, it does the same thing as VPLaunch, just goes to a black screen.  But I found that if I click the mouse then hit escape I can go back to where I was.  Also, if I wait long enough I can hear the music for the rom that I was attempting to load...so further "hacking" found this option in lconfig file: "LAUNCHSTYLE=0" I switched it to "1" and it loads up...not correctly, though, in a window, with a black screen behind it that if I click on it then hit escape I go back.  So the problem must lie in the "layering" of programs?
I have no clue, someone help!!  :P ??? :o :-\ :'( :-X :-[
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
« Reply #2 on: March 27, 2004, 10:45:02 am »
Try these settings for VP. They work for me first time ;D
Set emulator EXE to vp-launch2.exe
Set 'List generation method' to 'ROM Folder Only'
Set the ROM Folder to your tables folder in Visual Pinball
Set ROM extension to VPT
Show DOS box = False
Send ROM path = False
Use Long filename = False
Send ROM Extension = False
Ths should work.
« Last Edit: March 28, 2004, 05:06:18 pm by DBut »
  • Last login:June 29, 2026, 11:23:56 pm
« Reply #3 on: March 28, 2004, 04:51:45 pm »
Look at the app bonanza thread.... try the new one, it may help.  Normally I'd troubleshoot for you, but to be honest I'm extremely busy atm.  Sorry.  :(
BobBorakovitz
« Reply #4 on: March 31, 2004, 06:42:34 pm »
ok I've tried the new VPLaunch, it now opens the table fully, but it doesn't let me escape. (without hitting quit) when i do hit quit it brings me to a black screen where if I hit escape it'll bring me back to where i was.  I still think it has something to do with the "layering" of programs...
I thought I might've had a good idea, I thought the taskbar is set for "always on top" I disabled that hoping that was it, but it didn't do anything :(
Oh, BTW I'm using Win98...I don't know if I mentioned that before.  what's everyone else using?  Win2k? XP?  maybe that's it....
if someone has any info, please help me  ???
« Reply #5 on: April 01, 2004, 12:32:15 pm »
You have to hold down the key, not just tap it.  It'll exit in 98
BobBorakovitz
« Reply #6 on: April 05, 2004, 09:13:57 pm »
Hi Howard, I've just tried again VPLAUNCH4 and it does load the table but i press (and hold) the escape key and it does nothing, also it doesn't seem to close the VP Editor...
this is my last try... ???
BobBorakovitz
« Reply #7 on: April 07, 2004, 01:55:01 am »
ok, I just couldn't get the thing working in Win98, so I have no solutions, but I just got in my new hardware and installed Win2k,
the thing works flawlessly, seriously, try this, it rocks!  ;D
