Author Topic: Analog controls question  (Read 2875 times)
TheManuel
  • Last login:April 09, 2025, 10:13:43 pm
  • On and off hobbyist
« on: July 15, 2002, 11:44:37 pm »
I'm thinking about incorporating an analog flightstick, a steering wheel, a trackball (besides the regular mouse), a game pad and the I-pac on my upcoming control panel.
Of course, that will involve a lot of inputs.
Can I split the mouse port or the game port and use either input device going in through the split?
I don't expect to use both at the same time but would want to switch between them without having to diconnect anything.
Thanks.
"The Manuel"
Re:Analog controls question
« Reply #1 on: July 16, 2002, 04:22:22 am »
If all your devices are PC devices, then you could do something like: Mouse in PS/2 port, Trackball in Serial/USB port, Steering Wheel & Flightstick in USB ports.
OR If you need an interface for the controls then I guess the Opti-Pac would be a good solution.
Either way, you should be able to use any of these devices without disconnecting/connecting anything.
PS you forgot about a spinner :)
"The Manuel"
Would MAME recognize any analog inputs?
« Reply #2 on: July 16, 2002, 09:02:36 am »
... as far as they work on windows?
I figured I could do without a spinner since I don't think I play any games that used one (I could probably use the trackball or steering wheel if I need it).
The connections I'll have to make will have to depend on what devices I get for a good price.
Are
« Reply #3 on: July 16, 2002, 10:09:11 am »
The way I described will work perfectly in Windows, if you're using DOS then the USB devices will go out the window...
I guess you can use >1 serial device & gameport as well if neccessary (to cut down on USB devices).
I'm thinking dedicated PC devices will be cheaper than say proper arcade devices + interface.  Unless you can get a cheap (eg) arcade steering wheel from ebay & make your own interface (?).  Not all PC devices will be suitable tho - eg you might want a 360degree steering wheel, but most PC ones are 270deg.
The trackball will be fine for spinner games btw.
Hope that helps
"The Manuel"
What about the splitters?
« Reply #4 on: July 16, 2002, 12:06:18 pm »
Thanks for the help.
I do plan to but PC devices.
Do you know anything about whether there are splitters for mice and game ports?
« Reply #5 on: July 16, 2002, 01:46:11 pm »
You can certainly get splitters for game ports, BUT the game port only supports 4 buttons in total - so if you use a splitter that will be 2 buttons per joystick/pad.  Hopefully this wouldn't be a problem, as you can use keys for buttons using the I-Pac.
I don't think you can get a splitter for a PS/2 mose port, but I'm not 100% sure.  I've never seen one anyway.
You could use a serial (COM) port for a mouse/trackball.  I believe you can get a PS/2 to serial adaptor for this if necessary.
I think you may have to use the USB port(s) as you have so many devices to plug in.  I'm guessing but I bet most wheels/analogue sticks are USB now anyway.
"The Manuel"
« Reply #6 on: July 16, 2002, 03:37:41 pm »
Very good points:
Thanks.
