Author Topic: Dremel Drill Contol holes?  (Read 1300 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: March 22, 2004, 07:53:49 pm »
My dad has a dremel hand held tool. I am not familar with this tool. Will it drill holes for control panel buttons?
Will it drill through wood? plastic? thin steel? aluminum??? plexi?
thanks
Demon-Seed
Re:Dremel Drill Contol holes?
« Reply #1 on: March 22, 2004, 07:54:42 pm »
HHEHE topic should be Control Holes?
Jim ;D
crashwg
« Reply #2 on: March 22, 2004, 08:05:04 pm »
A dremel could do it with some of the various attachments out there for it, but a drill and drillbit would be the best choice.
And FYI, you can re-name the topic, just modify the original post.  If you do that though you may want to remove your second post to avoid confusion.
« Last Edit: March 22, 2004, 08:09:26 pm by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
NoOne=NBA=
« Reply #3 on: March 22, 2004, 08:51:23 pm »
They are not really made for that type of operation.
The chuck is too small for the bits you need to do it right, and the motor doesn't have enough torque to move much wood.
They are designed more for grinding type stuff than drilling.
To drill with it, you'd have to basically grind out the hole to get it the right size.
If you can get access to a drill, you'll finish it much better, and alot quicker.
« Reply #4 on: March 22, 2004, 09:35:09 pm »
Yeah, all you need is a drill, and a 1.125 (1 and 1/8th) inch hole saw...  that will make short work of drilling control panel holes.
Demon-Seed
« Reply #5 on: March 22, 2004, 09:57:43 pm »
Hello
thanks guys
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
« Reply #6 on: March 23, 2004, 02:34:03 pm »
Even my nice power drill took so long and got so hot using a forstner bit on pine that I purchased a drill press.
Wowser.  I think this thing will be my friend for a long time to come.
If you know someone who has a drill press, bug them till you can use it.  It won't take long.
b
What was that again?
