Author Topic: Which Restior Do I Need?  (Read 2144 times)
voodoochile
  • Last login:March 20, 2004, 09:50:29 am
  • RIP CA
    • VoodooMachine
« on: March 21, 2004, 05:07:33 pm »
I bought a couple of Linrose Super Bright LED's the other day (white light LED). I am using them to light my mini marquee :
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=16483
Anyway I am not sure what type of resistor I need (or if I even need one at all).
Power I am connecting them to is +5V
Now the package says Rectifier Diode must be used for AC application (huh? but you can help me with that later)
Then it says 6V 100 ohms for AC
                    12V 330 Ohms
                    28V 750 ohms
I want to put 2 diodes in parellel
Well here is all the info on te back. (see pic)
What do I need? Im confused..Help me Obi-one your my only hope.
BTWthis is the 5100 series:
Turn Failure into Success
Knievel
    • Knievel Kustoms
Re:Which Restior Do I Need?
« Reply #1 on: March 21, 2004, 06:06:09 pm »
Here's a great page for this:
http://www.projectx.com/Kits/LEDNotes/
They've got great prices on superbright LED's too  ;)
brooksware2000
  • Last login:April 20, 2004, 12:38:50 am
    • Hobbybotics.com
« Reply #2 on: March 21, 2004, 06:08:30 pm »
Using 5V dc I would say that you are safe using a resistor between 150 to 220 ohms. You do not need a rectifier diode if you are powering them from dc.
voodoochile
  • RIP CA
    • VoodooMachine
« Reply #3 on: March 21, 2004, 06:57:00 pm »
Thanks..electricity makes me stoopid sometimes :)
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #4 on: March 22, 2004, 12:43:46 am »
Oh, I'm glad someone asked this!  Not sure how to read mine either!  It is part number B4304H6-1.  I want to use 12V DC.  Am I to read the top chart or the bottom chart because it is a 4304...?  I'm an electrical degenerate  ???
Next I'll be on fries, and that's when the big money starts rolling in.
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #5 on: March 22, 2004, 12:56:24 am »
I have no idea how to read the back of that card. Here are the specifications for your LED. http://www.itcelectronics.com/pdtl-revised.asp?P=3009
The you can use the calculator located here to determine the correct resistor for your LED.
http://ourworld.compuserve.com/homepages/Bill_Bowden/led.htm
brooksware2000
    • Hobbybotics.com
« Reply #6 on: March 22, 2004, 09:26:27 am »
Looking at the chart that you provided I would say that you need the 5.1k or 3.9k 1/4watt resistors. You can you a value as close to the 5k or 3.9k as possible. I would shoot for a 5k as they are really common. So at 12vdc get yourself a 5k and you should be fine.
Nannuu
« Reply #7 on: March 22, 2004, 11:15:21 am »
Thank you!
