Author Topic: Wiring LEDs to my PS2 PCB board?  (Read 1158 times)
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« on: March 21, 2004, 11:17:36 am »
Hey guys, I have some translucent buttons for a dual panel I am building and I wanted it to have like an LED per button. I know that some might say just put a florecent light but I can't because the control panel is removable so I kinda wanted to power it up from the PCB. Now I know that you all know that every PS2 PCB has a 5v+ current running from it. I was wondering if that would be enough to run about 9 LEDs? Please reply. Thanx.
-See Ya!!!
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:Wiring LEDs to my PS2 PCB board?
« Reply #1 on: March 22, 2004, 02:46:14 am »
I'm certainly no expert on this (just barely getting the hang of it myself), but my understanding is that no, it work work.  See RandyT's response here when I asked a very similar question a year ago.  :)
Hellfromabove
« Reply #2 on: March 22, 2004, 01:23:37 pm »
Ah thanks a lot man I really appreciate it. Thanx.
-See Ya!!!
RandyT
  • Last login:September 16, 2026, 01:59:26 pm
    • GroovyGameGear.com
« Reply #3 on: March 22, 2004, 04:36:07 pm »
Well, you should always use caution, when it comes to this stuff, but you can probably get away with it.
Just be warned, though, that too many LEDs and/or sloppy wiring can cause permanent damage to your motherboard.
Nine LEDs should pull less than 200ma so it's not all that much.  It depends on your MB.
It's your call.   :)
RandyT
