Author Topic: SNK Rotary joystick controller project  (Read 5195 times)
brooksware2000
  • Last login:April 20, 2004, 12:38:50 am
    • Hobbybotics.com
« on: March 19, 2004, 10:55:59 pm »
I am working on a rotary joystick encoder project that I will release to the boards for the Ikari warriors style rotary joystick. Functionality will be similar in function to the druins controller currently selling for $45. I am not expecting to make money off this project, just want to present it to the board if anyone is interested in helping out with the project. I will be using Microchip 16F628 chips because that is what I have lying around.
Hit me up if anyone is interested in working with me on this project. I am really close to a working prototype on paper, just need to start coding and tesing.
geekbrain
  • Last login:September 08, 2006, 11:02:20 pm
  • Electrical Engineers are Geeks!
Re:SNK Rotary joystick controller project
« Reply #1 on: March 20, 2004, 05:05:29 pm »
Brooksware2000
This was debated around Christmas.  A little bit of a pissing contest ensued.  I have written code for a PIC16F84 (because that's what I had laying around) for a friend.  Works with an IPAC and seems to catch all the keystrokes in something like Wordpad but jumpy in MAME32.  I can email if your interested.  I was going to share on the board as well but haven't done so until I figure jumpy problem out.
Geekbrain
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: March 20, 2004, 05:21:01 pm »
Brooksware2000
Geekbrain
Jumpy Problem (My Guess) - The true SNK rotaries are set up so each click was one turn of the character (not sure if it was 30 or 45 degrees).  This is a pain to work with a keyboard or mouse, so MAME is set-up so that the character rotates from when the key is initially pressed until the key is released.
What this means is that rotating the stick slowly causes the switch to be closed too long, and the character over-rotates, and rotating the switch too quickly causes the character to under-rotate.
Mc-Escher and JerryJanis added code to make the rotary games a true one-increment per button press option.  Urebelscum added this into MAME Analog Plus.
Try your interface with MAME analog plus, and map the outputs from your interface to Button 4 and Button 5 in MAME analog plus instead of the DIAL inputs.
For example, MAME currently has DIAL set to something like Z and X on the default codeset.  Assuming you have you I-PAC and interface set so rotation is Z and X, go into the TAB menu in MAME analog Plus and set Dial to "NONE" (or some unused key) and set P1B4 to Z and P1B5 to X (P1B4 and P1B5 inputs will not be available in the official MAME version).
brooksware2000
    • Hobbybotics.com
« Reply #3 on: March 20, 2004, 09:36:55 pm »
Brooksware2000
Geekbrain
Yeah, send me what ya got and I'll take a look at it. I've gotten it to work pretty well using LED's to test the output but I am still refining things a bit. I'd love to take a look at what you have as well. email me at chbrooks@srt.com
brooksware2000
    • Hobbybotics.com
« Reply #4 on: March 20, 2004, 09:39:59 pm »
Brooksware2000
Geekbrain
That's great information, I have not tried analog mame yet so I will be testing with that as well. I figure that we can work on something that all can benefit from without it costing to much. Heck, I think I paid about $1.00 a piece for the pic chips.
spidermonkey
  • Bombjack junkie
« Reply #5 on: March 21, 2004, 02:04:05 am »
Uh oh, does this over/under rotate problem occur with Druins interface as well ? I'm using MAME 32 and I picked up one of Druins interfaces a couple months ago but I haven't hooked it up yet. Am I going to have to use MAME Analog plus with Druins interface or will it work ok with MAME 32 ? The reason I ask is because I haven't figured out how to use regular MAME yet.  ::)
"Sinistar has bad breath"
knuttz
  • Last login:January 08, 2025, 05:36:02 pm
« Reply #6 on: March 21, 2004, 03:02:45 am »
Hey geekbrain would you mind sending your code my way also.  I have some friends that can help me program PICs at my school.  My email is matthewknotts@hotmail.com
"Look at all those hamburgers. You can't eat all those hamburgers you stupid fella, OH GEEZ!" "OH he's gonna do it! He's so rediculous."
menace
« Reply #7 on: March 21, 2004, 07:57:55 am »
Lilwolf
« Reply #8 on: March 21, 2004, 12:04:10 pm »
If you are going to do it... at least try to make it configurable to work with analog mame
it works SO MUCH better its amazing!  Time solders is fun with direct connects... and left-rights... but it sucks with trying to sime out how long each click should be....  Really sucks!
Anyway..  if Analog+ Mame worked with ikari warriors and a few others with direct connect.  I would recommend just making a special 24 key encoder of some nature and using that.  I only have one connected this way... and it was SO much nicer... that I gave up on using the regular way to do it..  Just waiting...
geekbrain
« Reply #9 on: March 21, 2004, 12:11:43 pm »
I'm glad to see someone read the old post rather than having to rehash anything.  Brooksware2000 and knuttz - I will email tomorrow - I have the code at work at the moment.  I have absolutely no problem sharing the hex file freely in the spirit of MAME.  I will share the assembly source as well with the provision that if you use it you give credit where credit is due - don't plagarize and say you created it.
And most importantly - DO NOT ask me to burn chips - there are all sorts of resources on the net for doing this.  I'm an electrical engineer and have learned several useful things from the MAME experience that I have been able to apply at work.  Use the opportunity to learn something!
Like I said in my first post of this thread - the PIC code I have works well with the IPAC using Wordpad - it catches every detent (360 dgrees/12 = 30 degrees BTW).  The problem appears to be with the MAME setup.  It also might have to do with IPAC connection or motherboard BIOS (keyboard frequency) - it's presently been used with keyboard interface instead of the USB.  Don't know if that matters.  Again I will openly share based on my above comments!
brooksware2000
    • Hobbybotics.com
« Reply #10 on: March 21, 2004, 12:19:17 pm »
No problem with that. I am a computer programmer myself and I spend so much time writing code for someone else I don't get enough time to do it for myself. I want this to be a free-for-all project. I think that we can all benefit if we work together on this. It sucks for someone to borrow from someone else without giving credit were credit is due. All the code that comes from this will be posted here for others to use/modify (with the consent of those whose portions of code may be included). If not for anything else but as a learning experience for others.
The Mame project itself is free so we can work to expand it even further with such projects as this.
Thanks to all ahead of time that are interested in this and want to help out.
knuttz
« Reply #11 on: March 22, 2004, 01:47:03 am »
Thank you so much.  I am very excited with this project and learning how to burn/possibly program PICs.  Also don't worry, I would never try to take credit for your work or anyone else's.  Thanks again.
Matthew
Tiger-Heli
    • Tiger-Heli
« Reply #12 on: March 22, 2004, 08:04:06 am »
It occurs with Druin's interface.  Specifically, I only KNOW of it occuring with Druin's interface and a custom non-interfaced rotary I was working on (with help) a long time ago.  I assume it would be a problem with these other interfaces as well.
You don't HAVE to use MAME Analog Plus with it, but otherwise you'll have to tweak the analog settings for each game, and while you can get pretty good results, it won't be perfect.
If you want to stay with MAME32, the analog plus changes have been added to NoNAMEMAME and NNM has a mame32 build - https://sourceforge.net/project/showfiles.php?group_id=91067&package_id=95932
And you can contact me if you want to migrate to command line MAME.
rdagger
« Reply #13 on: March 22, 2004, 08:56:19 pm »
Here's that other thread in case anyone was interested
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=14166
I had very good luck building my own rotary interface.
Here are the schematics and pics:
Rotary Interface
« Last Edit: September 02, 2006, 01:22:11 pm by rdagger »
brooksware2000
    • Hobbybotics.com
« Reply #14 on: March 23, 2004, 12:03:04 am »
http://69.33.42.246/Arcade/ri.aspx
How did you overcome the debounce problem with the contacts on the joystick sending false signals as they slid across the terminals. I have yet to come across a solid way of dealing with this issue
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #15 on: March 23, 2004, 07:44:08 am »
I would like to gauge interest in bulk buying LS-30 rotary joysticks and saving us all some cash. I reckon most people want at least two. I am probably not the best person to arrange this, as I am located in Europe where supplies of this particular item are non-existant. Better would be someone in the US or Asia to source a good deal (with VideoConnect perhaps?) .
Any interest in this? Anyone willing to pick up on this?
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #16 on: March 23, 2004, 09:44:53 am »
When I bought my two LS-30s from Video Connection (about a year ago), the operator told me that they had just one case left.  They could very well have been lying, or just making an excuse for why the sticks were $30 each, but think about it...there is ONE place that we know of online to buy them.  Supposedly they are out of production, which doesn't surprise me.  I think you'll be hard pressed to find these at a discount, or in any large quantities at all, for that matter.  Sorry to burst your bubble.  :)
Coleman
WonderMellon
  • Last login:February 10, 2019, 12:41:23 am
« Reply #17 on: March 23, 2004, 12:36:01 pm »
Coleman
Coleman,
  I think you are correct about this.  I can't believe I didn't pick these up when they were $30.  The first time I ran across them they were still $15.  The cost of being a procrastinator I suppose.
There are several people putting effort into creating an interface for these.  Is there any possibility for taking a standard 8 way and making it a rotary?  It sounds like there may be some interest for it if it can be done.
Tiger-Heli
    • Tiger-Heli
« Reply #18 on: March 23, 2004, 12:57:26 pm »
Coleman
Coleman,
I have an on-again/off-again project to add a couple of switches and an actuator to a standard joystick and have a mechanical rotary that doesn't need an interface.
It's more off-again now though . . .
mp2526
  • Last login:August 11, 2023, 02:30:47 pm
    • Miavio
« Reply #19 on: March 23, 2004, 02:16:37 pm »
You mean like this?
http://www.happcontrols.com/joysticks/rotary_optical_joy_e.htm
WonderMellon
« Reply #20 on: March 24, 2004, 02:24:17 pm »
You mean like this?
I don't think so.  I believe that one is optical and not mechanical.  So it operates more like a mouse than a switch.  It also looks like it has a stop on it to prevent it from 360 degree rotation.
« Last Edit: March 24, 2004, 02:25:10 pm by WonderMellon »
mp2526
    • Miavio
« Reply #21 on: March 24, 2004, 02:27:22 pm »
Take a look again.  It comes in two flavors.  One is optical and one is mechanical.  It may be easier to tell that on the main page here:
http://www.happcontrols.com/joysticks/rotary&optical_joy.htm
Edit:  Oh, and that stop you see is not for stopping the switch from turning 360, but rather to keep the switch body from rotating when you rotate the joy shaft which is attached to the switch shaft.
« Last Edit: March 24, 2004, 02:29:41 pm by mp2526 »
