Author Topic: How do I Angle an Image??  (Read 1422 times)
GGKoul
  • Cheesecake Apprentice
« on: March 18, 2004, 11:32:24 am »
Hello
I'm trying to get this empty Tron Marquee (Image #1) to fit my control panel which has angled lowered corners.  (Image #2)
My question is, how do I modify the Tron image so the lines of the image follows the angle of my control panel? Is there a way I can drag the corners of the Tron imaged to fit my control panel measurments??  If so how??
-GGKoul
GGKoul
Re:How do I Angle an Image??
« Reply #1 on: March 18, 2004, 01:51:01 pm »
Let me phrase the question this way.
How do I squeeze the Tron image in to a custom shape?
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #2 on: March 18, 2004, 03:14:43 pm »
You could add perspective or something. In Photoshop I selected the bottom half and added some perspective to make the bottom angle inward.  But it will probably look weird. Something like this:
« Last Edit: March 18, 2004, 03:15:58 pm by patrickl »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #3 on: March 18, 2004, 03:27:07 pm »
I did it with Photoshop. Select the bottom part (where the angled sides are) and add perspective (Menu Edit -> Tranform -> Perspective) I guess you could use another program as well.
Oh and then I filled the bit that came up empty with black, but I guess I should have set the background to black before I added the perspective.
« Last Edit: March 18, 2004, 03:28:35 pm by patrickl »
patrickl
  • Yo momma llama
    • PocketGalaga
« Reply #4 on: March 18, 2004, 05:22:00 pm »
He he yes, well I warned that it looked weird.   ;D
I don't understand what you mean by WRAP though. You could use a mesh deform (Photoshop or Paintshop has that) or maybe a raytracer?
Can you give a sketch of what you want it to look?
