Author Topic: Help to fix a Midway HyperDrive Yoke Joystick  (Read 1493 times)
GGKoul
  • Cheesecake Apprentice
« on: March 11, 2004, 09:17:46 pm »
Hello
I just acquired this non working Yoke joystick that was used on a Midway Hyperdrive cab.  And I have a question for the experts out there.
Based on the pictures I've posted. What do I need to get the Yoke joystick in working order??
I understand I need to purchase a Gear and another "pot"  (whatever that is).  But do you see any other parts I may need
And does anyone know where I can purchase these parts?
Many Thanks!!
-GGKoul
« Last Edit: March 12, 2004, 01:48:37 am by GGKoul »
GGKoul
Re:Help to fix a Midway HyperDrive Yoke Joystick
« Reply #1 on: March 11, 2004, 09:19:17 pm »
Picture 2 of the internals
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
« Reply #2 on: March 12, 2004, 01:43:54 pm »
It appears you are also missing the parts needed for the x-axis.  They would be similar to what you've got for the y-axis there (some sort of turntable bearing, pipe to hold centering springs and to house wire, another set of gears and a pot, and any mounting hardware).
Also don't forget you'll need something to interface this to the PC.  If you use 100K pots this could be hooked to a standard joystick port connector.  Or you could use 5K arcade pots and hook it to a hacked Microsoft sidewinder joystick (USB).
Gamecab
  • Last login:March 06, 2008, 05:34:27 pm
  • Flight Yokes - 9/10/05
    • GameCab
« Reply #3 on: March 12, 2004, 10:06:10 pm »
GGkoul,
Would you like to send it to me, I can add the needed pots and gears to complete this for you?
Charlie
The Flight Yoke Release date is September 10, 2005.
GGKoul
« Reply #4 on: March 12, 2004, 10:24:47 pm »
Gamecab.. Wow!! Thanks forthe offer... I just sent you a PM.
