Author Topic: MaLa 2.0+ - New Feature ideas  (Read 43834 times)
0 Members and 41 Guests are viewing this topic.
loadman
  • Moderator
  • Last login:Today at 09:48:43 pm
  • MaLa FE developer
    • MaLa
« on: September 26, 2026, 09:29:59 pm »
As you will see in the other post, MaLa 2.0 Beta 1 is being tested by a small group for now.
This is mainly to improve stability, so there's a strong foundation to add new features.
As for potential new features, here are some ideas:
Already planned
These are happening regardless:
Coming in 2.0 Final
  • The companion tools, rebuilt for 2.0 - GameList, Tree, Layout, AttractMode and PluginTester ship alongside MaLa.
  • Launch buttons for those tools in the settings screens - right where you configure the matching feature, e.g. the Layout editor button next to the layout settings.
  • Missing artwork and video report - MaLa checks your game list against the artwork your layout uses and writes the gaps to a file, ready for a bulk downloader such as ADB-Tools.
  • Links to recommended companion tools - on malafe.net and inside MaLa, such as looking a game up on Arcade Database.
Potentially Coming in 2.1
  • Second-screen marquee support - a dedicated LCD marquee panel above the main screen, showing artwork for the selected game.
  • Multiple languages - MaLa's menus and settings in other languages, starting with German, French and Spanish, and open to community translations.
Some potential ideas that will keep me busy for a while - feedback welcome
These are features I'm considering. Nothing here is promised, and there's no set order yet.
If any of these would make a difference on your cabinet, or you think something is missing, reply and let me know.
Game lists and launching
  • Run without MAME - use MaLa with only other emulators and/or the Jukebox, no MAME install needed.
  • Portable game lists - lists keep working when a drive letter changes (USB drive, cloned build, moved install).
  • Show the game name, ROM name, or both in the game list.
  • Fall back to a clone when the parent ROM is missing (or vice versa), instead of failing to launch.
  • Print or export the game list to text or CSV.
  • Multiple emulators in one game list - e.g. MAME, Model 2 and Naomi games side by side.
  • Multiple MAME versions side by side.
  • Auto-quit idle games - return to MaLa after a game has been left idle for a set time. Would you want the game to quit, MaLa to quit, or both?
  • Playlists.
  • Play counts shared across layouts.
Layouts and display
  • More game info in layouts - source file, driver status, ROM path and more, updating as you move through the list.
  • History.dat display fixes.
  • Hi-score display in layouts (HiToText).
  • Animation in layouts, including animated starting screens.
  • Transparency in layouts - layers over video, transparent game-list pictures.
  • Background video in layouts.
  • Auto-scaling layouts for different screen resolutions.
  • Word wrap in layout text.
  • Cocktail and rotation improvements.
  • Windowed mode.
  • Horizontal or sideways game lists.
  • Music spectrum analyser - bars moving to the background music.
Controls and navigation
  • Button combos and multiple keys per action, including a combo to quit.
  • Wrap-around scrolling in the game list.
  • Tree shortcuts - skip the game-list selection screen, hide the main emulator list.
  • Small button conveniences - both Start buttons launch, a button to show flyers.
Starting a game
  • Hide the "starting game" window.
  • Show the game's snap or image in the starting window.
Hardware and configuration
  • USB character LCD support (Matrix Orbital, Crystalfontz).
  • Modern MAME config controls - video, filters, HLSL/BGFX.
  • Support fot Strem Deck Control - Admin, coin adding etc
Thanks,
« Last Edit: September 27, 2026, 02:55:10 am by loadman »
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 10:36:49 pm
Re: MaLa 2.0+ - New Feature ideas
« Reply #1 on: September 27, 2026, 07:41:44 am »
I vaguely remember trying out old Mala, many years ago. I liked it a lot, most people liked it. I want to give new Mala another go.
I might be mistaken about this, but: the reason I recall for not using old Mala was because the games lists forced the title text "GAMES LIST" to also appear. This annoyed me because I also wanted to have music playlists available from the menu, and to have "GAMES LIST" at the top of a list of music playlists would have looked dumb.
So my single, uncomplicated request of is: that the new Mala does not force you to have "Games List" appear above the games lists. Instead, it could be a text string variable instead, so I could replace it with something like "Music" or "Albums", or just something else instead. Even just to have the option of the "GAMES LIST" text *not* appearing would be better than nothing.
Again, I could be completely mistaken about this, apologies if that is the case.
EDIT: I thought about volunteering as a beta tester, but honestly I don't have the time so I didn't want to waste yours. But really looking forward to the new Mala   :cheers:
« Last Edit: September 27, 2026, 07:43:27 am by Zebidee »
arquillos
  • Last login:Today at 04:26:43 am
« Reply #2 on: September 29, 2026, 07:45:22 am »
Impressive!  :applaud: :notworthy:
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #3 on: Yesterday at 09:26:51 pm »
Sounds easy to implement.
When you next try MaLa send me a screenshot of what you are describing and I will add what you want/need.
arquillos
« Reply #4 on: Today at 04:27:36 am »
May I suggest some kind of integration or support with: https://github.com/mausimus/ShaderGlass?
loadman
  • Moderator
  • MaLa FE developer
    • MaLa
« Reply #5 on: Today at 07:40:27 pm »
I will put it on the list :-)
