Author Topic: GroovyArcade reinstall HELP - monitor black when launching games - config issue?  (Read 3543 times)
skottles
  • Last login:July 03, 2026, 06:14:33 pm
I had reinstall GroovyArcade recently after i attempted to update something and it would no longer boot.  I am struggling to get it going again as the initial install i was seeing vertical sync issues when Attract Mode loaded. I was able to track down a previous backup the syslinux.cfg file and I am now able to get into the frontend. This is what was in that file:
Code: [Select]
default arch
timeout 0
prompt 0
#UI vesamenu.c32
menu title Groovy Arcade Linux
label arch
menu label GroovyArcade
linux /vmlinuz-linux-15khz
append root=/dev/disk/by-uuid/0ee19b5e-93da-43d4-a6ef-237b9ffcfe75 rw quiet rd.udev.log-priority=3 splash mitigations=off audit=0 monitor=arcade_15 video=VGA-1:640x480iS
initrd /initramfs-linux-15khz.img
When I attempt to launch a game from the Attract Mode, I get black screen on the arcade monitor. Pressing ESC does not bring me back to the front end - i have to reset the computer. I think the game is playing blind here because I can hear audio.
If I hook up an external monitor when it is in this state, it displays an empty command prompt on the secondary monitor. If the 2nd monitor is hooked up when I launch the game, video displays on the external monitor - and pressing ESC returns to Attract Mode.
Right now i am just using the default roms that included GroovyArcade and no other changes other than the syslinux.cfg file have been changed on the install.
This was all working a week ago, so i know that it is possible to get this going again. What can i do to further troubleshoot this? Does this sound like a sync issue or config issue?
Software:
* GroovyArcade 2024.07
Hardare:
* MK1 Cabinet - Dedicated
* Chasis: Wells Gardner 25K7197
* Tube: Zenith
* ArcadeVGA 5000 PCI-E
* JPAC USB Version
* MSi H110M GAMING mother board
Calamity
  • Moderator
  • Last login:July 11, 2026, 06:03:47 pm
  • Quote me with care
Hi skottles,
Before anything, try this:
In the kernel line, add an 'e' at the end of this:
video=VGA-1:640x480iSe
Then, in switchres.ini, set:
dotclock_min 8.0
Steps to create a log:
skottles
Hi Calamity -- thanks for the suggestion here. I modified both of these files, but the same issue persists. Anything else i can try?
