Author Topic: Ami Rowe JAL 200 stopping switch/ reset assembly proper alignment  (Read 74338 times)
63rowe
  • Last login:September 04, 2026, 08:18:03 am
What is the proper alignment mark for this assembly after I set the record carousel at A1 ? Does the 200 mark have to be pointing right at the step on the search unit mounting bracket ( causing the 200 mark to be skewed slightly) or does it merely have to be facing the step in a straight line (as pictured in the manual) ?
« Last Edit: June 24, 2026, 04:55:13 pm by 63rowe »
