Author Topic: GM 0.287 real-time PART audio backend - frontend audio suspend shell script  (Read 19258 times)
nix999
  • Last login:Yesterday at 10:01:03 am
I have been following GroovyMAME real-time tips and configuration in the real-time.md instructions.
As to my understanding I now have a real-time system up and running which is very very cool :-).
The PART real-time audio backend requires exclusive ALSA access. This is an issue when using a frontend.
To that end I modified and beautified a launcher script I've been using for some years.
Of course, this works on my system but it might require some modifications on other systems as I am running a completely custom installed Arch.
So, I now have AttracModePlus happily playing audio, managing GroovyMame that is able to output sound through its PART real-time audio backend.
The only (very minor) drawback is that you will have to wait one second or so for the audio server to be restored when exiting a game.
Whereas previously AM+ re-appeared quickly this now takes a tiny bit longer but hey ... I do not care.
Of course, this comes with 0.0% warranty.
Code: [Select]
#!/bin/bash
# groovymame-launch.sh
# Version 0.0.1 - 09 June 2026
# Wrapper script for launching GroovyMAME(real-time) from AttractMode Plus.
# Handles exclusive ALSA access by suspending the audio server before launch
# and restoring it cleanly after exit.
# Usage:
#   groovymame-launch.sh <machine> [rom]
# Arguments:
#   machine   MAME machine name (or full path/filename — basename and extension
#             are stripped automatically)
#   rom       Optional ROM/cartridge path passed via -cart
# HOW TO DETERMINE WHICH AUDIO SERVER TO STOP
# GroovyMAME PART real-time audio backend requires exclusive ALSA access for
# latency-free audio. Any audio server holding the ALSA device open will block
# this. To find out which server is running on your system, run the following
# while the  frontend is active (before launching any game):
#   fuser /dev/snd/*
# This prints the PIDs of all processes with the audio device open. To resolve
# those PIDs to process names:
# fuser /dev/snd/* 2>/dev/null | tr ' ' '\n' | grep -v '^$' | xargs -I{} ps -p {} -o pid,comm=
# Common results and the corresponding stop/start commands:
#   PipeWire + WirePlumber ( my own current system):
#     stop: systemctl --user stop wireplumber pipewire-pulse pipewire
#     start: systemctl --user start pipewire pipewire-pulse wireplumber
#   PulseAudio:
#     stop: pulseaudio --kill
#     start: pulseaudio --start
#   JACK (jackd):
#     stop: jack_control stop
#     start: jack_control start
# Note: stop and start order matters for PipeWire — always stop wireplumber
# before pipewire, and start pipewire before wireplumber.
set -euo pipefail # exit on unhandled errors, unset variables, and pipe failures.
# Configuration
readonly SCRIPT_DIR="$(dirname "$0")"
readonly EXECUTABLE="mame"
readonly LD_PATH="/usr/local/lib"
readonly AUDIO_SETTLE_SECS=0.5   # time to wait after stopping audio server
# Logging helpers
log()  { echo "[$(date '+%H:%M:%S')] $*"; }
warn() { echo "[$(date '+%H:%M:%S')] WARNING: $*" >&2; }
die()  { echo "[$(date '+%H:%M:%S')] ERROR: $*" >&2; exit 1; }
# Audio server management
audio_stop() {
    log "Suspending PipeWire audio stack for exclusive ALSA access ..."
    systemctl --user stop wireplumber pipewire-pulse.socket pipewire-pulse pipewire.socket pipewire
    sleep "$AUDIO_SETTLE_SECS"
    log "Audio stack suspended."
audio_start() {
    log "Restoring PipeWire audio stack ..."
    systemctl --user start pipewire pipewire.socket pipewire-pulse pipewire-pulse.socket wireplumber
    log "Audio stack restored."
# Ensure audio is always restored even if the script is interrupted
trap audio_start EXIT
# Argument handling
if [[ $# -eq 0 ]]; then
    die "No machine specified. Expected: $0 <machine> [rom]"
fi
machine="$1"
machine="$(basename -- "$machine")"   # strip leading path if supplied
machine="${machine%%.*}"              # strip extension if supplied
rom="${2:-}" # use $2 if set, otherwise use an empty string
log "Invoking GroovyMAME launch script"
log "Machine : $machine"
log "ROM     : ${rom:-<none>}" # use $rom if set, otherwise substitute literal
# Launch
cd "$SCRIPT_DIR"
audio_stop
log "Launching GroovyMAME ..."
if [[ -z "$rom" ]]; then
    env LD_LIBRARY_PATH="$LD_PATH" ./"$EXECUTABLE" -cheat "$machine"
else
    env LD_LIBRARY_PATH="$LD_PATH" ./"$EXECUTABLE" -cheat "$machine" -cart "$rom"
fi
log "GroovyMAME exited cleanly."
# audio_start is called automatically via the EXIT trap above
« Last Edit: June 09, 2026, 10:43:23 am by nix999 »
Substring
  • Last login:September 18, 2026, 02:48:36 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Interesting .. But you don't need that if you just stick to ALSA without PulseAudio or Pipewire, do you ?
nix999
It depends what other software you have on the system. If I'm not mistaking there were build dependencies. I wandered a bit left and right while figuring it out. I can imagine that on a pure ALSA based system it is not needed. I do know for sure that AttractMode uses PipeWire on this build. But I have another identical pc. I plan on making a build script for the system so I can more or less build it all automatically. I want to strip it down to the absolute bare essentials. It's just that it feels like documenting and documentation is not one of my strongest points :-) ...
Substring
In the use case of GroovyArcade + KMS : there is no pipewire, no PA, just alsa. And it didn't require such system actions to get it working. But, this raises an interesting point : would it work on X/Wayland ?
nix999
I've had a look and I can also get away with pure ALSA it seems. As I said I experimented a bit to get everything working. As for GM plus PART audio on X/Wayland ... I would say yes ... Logic dictates it should work using the approach in the script. To test of course. But I see zero reason not to use KMSDRM.
