Author Topic: Sega Model 3 monitor reassembly - Solo help needed!  (Read 1671 times)
fablog
  • Last login:May 13, 2026, 05:28:16 pm
« on: May 12, 2026, 07:40:09 pm »
Hi everyone,
​I'm currently restoring a Sega Model 3 sit-down cabinet and I need to redo the monitor assembly. I think I messed up the order of the parts because I can't get the front plastic bezel to fit at the end of the process.
​I need to tilt the monitor back to start over, but I'm doing this completely solo and the weight of the 29" CRT makes me nervous.
​Could anyone share the exact steps or tips for the following when working alone?
​Tilting the monitor back: How do I safely detach the top and let the monitor tilt/rest back on its bottom pivot points without dropping it?
​Reassembly procedure: What is the exact step-by-step sequence to put the structure back together safely? I need to know the proper order to handle the monitor, the top metal crossbar, and the side panels when doing this by myself. (Note: The monitor's top metal ears mount to the front of the top crossbar).
​Thanks,
Fabien
Envoyé de mon Pixel 10 Pro en utilisant Tapatalk
