Author Topic: OutputHooker, a modern reimagining of MAMEHooker  (Read 131873 times)
PolybiusExtreme
  • Last login:September 25, 2026, 01:29:06 pm
« on: March 26, 2026, 04:58:00 pm »
OutputHooker
A modern reimagining of MAMEHooker, built for the latest Windows environments.
This tool acts as the essential bridge between emulators and your arcade hardware (Lightguns, LEDs,...).
Features
Windows Support:
Fully optimized for Windows 10 and 11, eliminating the stability and compatibility issues of MAMEHooker
Output Support:
Network - Receive output data over network connections for modern setups
Windows Messages - Full backward compatibility with the "old" Windows messaging system
This means that any emulator, launcher, or tool works with OutputHooker!
Output Processing Method - If an application sends outputs over both Network and Windows
Messages, *Settings* decides what happens. **Priority** uses the preferred output source and
falls back to the other one if it stays quiet, **Exclusive** uses only the preferred source,
and **Concurrent** processes both. The preferred source defaults to Network, and the method
defaults to Priority, so no command is sent to your hardware twice.
Hardware Support:
Lightguns with COM Port support (Blamcon, Fusion, GUN4IR, OpenFIRE, RS MX24, RS Reaper, X-Gunner)
Lightguns with TCP support (Sinden)
Positional Guns with USB HID support (Alien,...)
LEDWiz boards (Original, Clone, Pinscape)
Ultimarc LED boards
WLED boards (JSON API)
Gamecontrollers with SDL3 support (Force Feedback)
Any hardware that receives TCP/UDP commands
INI Support:
MAMEHooker INI files and KeyStates are supported
OutputHooker features a built-in editor inspired by the original MAMEHooker workflow,
allowing you to configure hardware triggers without leaving the app
MAME State Output Project Support:
MAME State Output Plugin by djGLiTCH is supported
Getting Started
1. Download the latest build from the GitHub Release page
2. Configure your emulator (e.g. MAME) to broadcast outputs via TCP or Windows Messages
3. Launch the application, start a game and use the INI Editor to define your hardware mappings
Watch your cabinet come to life!
Support
See the GitHub Wiki for detailed instructions.
Due to time constraints, I cannot offer any support.
I am just one man that wanted to build a modern MAMEHooker alternative for my selfmade Arcade machine.
Contributing
If you have suggestions, bug reports, or want to contribute to the code, feel free to open an issue or submit a pull request.
Credits
Howard Casto (MAMEHooker & MAME Interop SDK developer)
Ben Baker (MAME Interop SDK & Ultimarc SDK developer)
Aaron Giles (MAME output code developer)
djGLiTCH (MAME State Output Project (MSOP) developer)
6Bolt (Hook of the Reaper developer)
« Last Edit: July 24, 2026, 02:20:01 am by PolybiusExtreme »
bobbyb13
  • Last login:September 22, 2026, 12:49:50 pm
Re: OutputHooker, a modern reimagining of MAMEHooker
« Reply #1 on: March 28, 2026, 02:17:54 am »
I like it.
Cool work.
Always wanted to build a gun game machine so maybe it finally is in my future?
abispac
  • Last login:September 25, 2026, 11:17:01 pm
« Reply #2 on: March 29, 2026, 11:07:42 pm »
awesome, maybe ill update my igrosoft setup and build another cabinet, although im not sure if this would work as think it was mame that handles the coint counting for those games, to bad im stuck with an old version of mame for that.Ill try and see if this works
abispac
« Reply #3 on: March 31, 2026, 04:22:09 pm »
Instructions unclear, i fire up mame and outputhooker wont detect anything. Running mame and the hooker with admin privileges still nothing. Do i need to do something to tell the hooker so it detects mame? Thanks
Nevermind sorted out, testing it right now.
« Last Edit: March 31, 2026, 04:26:39 pm by abispac »
abispac
« Reply #4 on: March 31, 2026, 04:35:27 pm »
Works great with igrosoft games
PolybiusExtreme
« Reply #5 on: April 09, 2026, 03:28:26 am »
OutputHooker v1.1.0 released!
- Added "Launch Application" (apl) and "Close Application" (apc) commands
- Added KeyStates support
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.1.0
PolybiusExtreme
« Reply #6 on: April 14, 2026, 02:47:03 am »
OutputHooker v1.2.0 released!
- Added LEDWiz support
- Added new "Ultimarc - Set RGB LED Color" command
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.2.0
PolybiusExtreme
« Reply #7 on: April 15, 2026, 05:44:09 pm »
OutputHooker v1.2.1 released!
- Fixed a case-sensitive bug in the code
Please update to the new version!
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.2.1
PolybiusExtreme
« Reply #8 on: April 30, 2026, 02:03:07 am »
OutputHooker v1.3.0 released!
- Added support for Sinden Lightguns (TCP)
- Added support for WLED boards (UDP Realtime)
- Added support for TCP and UDP commands
- Added support for command line arguments
- Added commands for all Lightguns
- Added COM Port placeholder %cp#%
- Added "Ultimarc - Set LED Fade Time" command
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.3.0
PolybiusExtreme
« Reply #9 on: May 18, 2026, 05:44:04 am »
OutputHooker v1.4.0 released!
- Added support for positional guns
- Added support for SDL3 gamecontrollers
- Added "Connected Device(s)" window
- Fixed COM Port placeholder
- Fixed TCP read
Big thanks to 6Bolt!
Without him and HOTR, I probably would never have done OutputHooker.
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.4.0
PolybiusExtreme
« Reply #10 on: May 29, 2026, 03:39:00 am »
OutputHooker v1.5.0 released!
- Added support for HTTP POST requests
  (WLED JSON API works now!)
- Fixed default.ini usage
  (The default.ini works now like in MAMEHooker!)
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.5.0
PolybiusExtreme
« Reply #11 on: June 18, 2026, 05:05:30 am »
OutputHooker v1.6.0 released!
- Fixed HTTP POST request function
- UI changes for better performance
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.6.0
Anna2Kowalska
  • Last login:August 04, 2026, 01:27:39 pm
« Reply #12 on: July 10, 2026, 05:52:46 am »
OutputHooker
Features
Windows Support:
Output Support:
Hardware Support:
Ultimarc LED boards
INI Support:
MAME State Output Plugin by djGliTCH is supported
Getting Started
Watch your cabinet come to life! ahkaart helps you save on everyday shopping, leaving more of your budget for arcade hardware, gaming accessories, electronics, and DIY gaming projects.
Support
Contributing
Credits
Just grabbed v1.6.0 and it's running smooth on Win11. Finally got my Sinden guns and a couple WLED strips responding nicely during gameplay. The TCP support and INI editor make this way more pleasant to work with than the old MAMEHooker ever was.
PolybiusExtreme
« Reply #13 on: July 24, 2026, 02:48:05 am »
OutputHooker v1.7.0 released!
New Settings:
- Start OutputHooker Minimized
- Autostart with System
- Output Processing Method (Exclusive / Priority / Concurrent)
- Preferred Output Source (Windows / Network)
Fixes:
- Game-start commands no longer fire twice on a game's first run
- Network output reconnects after a settings change instead of staying dead until the app is restarted
- The apc close-app command no longer blocks output processing for up to 30 seconds while taskkill runs
- COM port placeholders resolved once when the INI loads, not on every command of every output
- A repeating error shows one dialog with a live count instead of stacking identical dialogs
BIG THANKS to DJ GLiTCH for his fixes and new features!
https://github.com/PolybiusExtreme/OutputHooker/releases/tag/v1.7.0
