Author Topic: Dreamcast and PC switcher??  (Read 4218 times)
jlampc
  • Last login:February 02, 2022, 07:33:58 am
  • I am not an animal !!! I am a gamer
« on: March 10, 2004, 02:24:41 pm »
I got good news today. My new Cab's 29 inch monitor is switchable to 15khz. ;D
Now I need to figure a way to switch between a dreamcast and a pc running Mame.
The pc will probably go out using an ATI card running 15khz. (here I come ultimarc)
the Dreamcast needs to be hooked up....Here's my question.
Can I hack a scart cable to output rgb at 15khz...
If yes
what would be the best way for me to switch back and forth from a pc to a dreamcast  for the Cab.
and Last. whats the best controller to hack for a control panel.
I'm going to start on the Cab this weekend!!!!!  :D
TalkingOctopus
    • My Arcade
Re:Dreamcast and PC switcher??
« Reply #1 on: March 10, 2004, 02:30:55 pm »
I used molex connectors to switch my arcade controls between the keyboard encoder and the DC controllers.  When I want to switch systems, I have to lift up my control panel and switch molex connectors, (Example: from controls to pc would be switched to controls to dc).
I used regular sega DC pads.  For more info about hacking them go here - http://members.cox.net/joysticks/
MrPoPo
  • Last login:March 10, 2004, 05:53:46 pm
« Reply #2 on: March 10, 2004, 06:00:14 pm »
Hi jlampc !!
I also have a DC plugged into my 15 KHz arcade monitor using an RGB cable.
I have one question about the quality of the image.
The problem is that the image flickers in my monitor.I don't know why, but it seems to be like when I run Windows on it in a interlaced resolution.
When you finish your project can tell me how you see it ??
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #3 on: March 10, 2004, 08:17:19 pm »
If yes
What kind of monitor is this?  And switchable between std res and med res? (or does it do vga/31khz?).
I find it easier to hack a DC-VGA box to output 15khz, and then just use a normal computer monitor switch box to switch between the DC and PC.
Dave_K.
    • Arcade Fever
« Reply #4 on: March 10, 2004, 08:20:19 pm »
Hi jlampc !!
There are a couple older Dreamcast games (like StreeFighter 3) that output an interlaced signal.  Sorry no way around that.
MrPoPo
« Reply #5 on: March 11, 2004, 09:45:06 am »
I have a low-res arcade monitor (only 15 KHz)
I have the same problem with all the games except one Japan game called Black Matrix.With this the image is static.
Dave_K.
    • Arcade Fever
« Reply #6 on: March 12, 2004, 04:29:13 am »
If you are seeing a flicker when playing something like Soul Calibur at 15khz RGB, then its probably something to do with your monitor (may need adjusting).
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« Reply #7 on: March 20, 2004, 07:54:48 pm »
If yes
Well to switch between my PS2 and DC pad I just used an SPDT switch and just used the switch to switch the grounds. Just one flip and I could use DC or just flip it again and I could use the PS2. This eliminated the purpose of trying to use a printer cable which I used once and I didn't really like it. Here's a link to the switch:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=275-711
Thanx.
-See Ya!!!
