Author Topic: What is the process for generating modelines specifically to match a CRT tv's  (Read 14980 times)
esc5879
  • Last login:December 12, 2025, 10:06:08 am
I was directed to here, however I don't know if I'm allowed to ask her because I'm using Batocera with CRT Script, not Groovy Mame or CRT Emudriver but maybe similar applies.
While I've gotten into installing crt script for Batocera to use with my crt tv for a long while now, I still have zero experience with this part of pc crt emulation set ups.
I've had issues with interference, and I'm starting to realize it might be because I have things configured wrong with the crt tool I used to configure it.
And now I'm just hearing about the idea of "generating your own modelines" to match your exact CRT TV's specs.
How exactly does one do this? My crt tv is the panasonic ct-27g24a. What is all the information that I need about my tv to do this? And when I have all of that, how exactly do I "make modelines" to match it?
I have no idea how to even search for tutorials because I don't know what terms to search in and I did try before posting here. So if you know any tutorials on all of this feel free to share with them as an answer.
makya
  • Last login:August 18, 2026, 06:34:04 pm
Just had a quick look and it seems this utilize switchres. So you set simple a range, like generic_15 or arcade_15. Why do you think you need a specific modeline for a specific TV ?
buttersoft
  • Last login:Today at 08:35:55 pm
  • Is running at 15kHz
Mayka is mostly right. Generating modelines is for when the generic_!5 or arcade_15 preset modelines don't work. Oe edge case usages - like when you need to run a game in a 16:9 mode because it's not happy otherwise, but you want the center 4:3 picture to fill a 4:3 screen and stretch out each side.
Substring
  • Last login:September 18, 2026, 02:48:36 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
I'd rephrase things a different way : you may need a custom crt_range that, in turn, will compute the good modelines for you.
The Batocera script is a little too raw and makes my eyes bleed.
For the custom crt_range, it's a tough task. You need to understand the meaning of each field, and test on the same modeline over and over until you reach something stable and flexible enough to allow a wide variety of modelines.
