Author Topic: Operation Thunderbolt + MAMEHooker 2 player script issue  (Read 12427 times)
Afterburner1970
  • Last login:February 17, 2026, 07:37:28 pm
« on: December 02, 2025, 02:58:42 pm »
Hi,
Ok, after losts of mucking around and reading many posts and help from Howard, I finally got both guns (on my Revolution X) working.
Only issue is when playing 2 player..... whoever pulls the trigger second, it stops the first players guns recoil.
It must be a script issue, so hoping someone can spot my error?
ini file
[General]
MameStart=
MameStop=kls 1
StateChange=
OnRotate=
OnPause=
[KeyStates]
RefreshTime=
[Output]
Player1_Recoil_Piston=lfs pistonthunder 20 %s%
Player2_Recoil_Piston=lfs pistonthunder-2 20 %s%
and the 2 script files
Pisonthunder.mhs
uls 1 1 0
uls 1 1 %s%
Pistonthunder-2.mhs
uls 1 2 %s%
uls 1 1 %s%
Many thanks
bandicoot
  • Last login:April 19, 2026, 04:39:57 am
Re: Operation Thunderbolt + MAMEHooker 2 player script issue
« Reply #1 on: December 03, 2025, 11:07:39 am »
hello i think
this mut be like this
Pistonthunder-2.mhs
uls 1 2 0
uls 1 2 %s%
  • Last login:Yesterday at 07:26:12 pm
« Reply #2 on: December 03, 2025, 06:25:57 pm »
to simplify even greater, you never have to pass a zero when the state is off.   I have that option in place for outputs with multiple values.   Just pass a %s%... when the output isn't firing the value of %s% will be 0 anyway.
Afterburner1970
« Reply #3 on: December 04, 2025, 11:24:59 am »
i had made a typo
the script is actually
uls 1 2 0
uls 1 2 %s%
but still have this issue....any thoughts?
Afterburner1970
« Reply #4 on: December 04, 2025, 11:27:59 am »
I should point out, as I didnt make this very clear..this issue is happening on operation thunderbolt. Revolution X is working perfectly.
Thanks in advance
TapeWormInYourGut
  • Last login:June 23, 2026, 07:34:06 am
« Reply #5 on: December 07, 2025, 11:41:31 am »
I have the same issue in Operation Thunderbolt and it's because the output states appear to be bugged in that game.
- snip -
Edit: The issue with mine appears to be due to a bug in my output software. It had an invalid line-terminator check which caused output messages to be queued until a new message was received. The delay in processing messages caused a result similar to what the OP is seeing. This is because the correct states weren't being immediately processed.
« Last Edit: December 23, 2025, 10:13:02 pm by TapeWormInYourGut »
