Author Topic: Model 2 led output?  (Read 936 times)
Endprodukt
  • Last login:Today at 05:02:37 am
Model 2 led output?
« on: August 14, 2025, 11:28:08 am »
Is there a way to get led output from the racing games to Mamehooker?
ramjetvr is only compatible with ultimarc and I'm using an Arduino.
SailorSat
  • Last login:Today at 02:38:59 am
    • For Amusement Only e.V.
Re: Model 2 led output?
« Reply #1 on: August 14, 2025, 11:39:30 am »
Mhm... MAME or M2EM?
Endprodukt
« Reply #2 on: August 14, 2025, 02:21:26 pm »
Model 2 but I already figured it out. Output blaster. I really hope we are going to see ffb in model 2 mame emulation.
Endprodukt
« Reply #3 on: August 14, 2025, 02:45:54 pm »
Yeah well while m2 did hook up through output blaster and created the ini the debug in Mamehooker shows 0 activity. Working fine with mame and supermodel. Maybe only 1.0 compatible....? I just want some lamps to blink haha
SailorSat
« Reply #4 on: August 15, 2025, 04:44:07 am »
Are you using my daytona lua script by any chance? It reroutes lamp data.
jorgenjl2
  • Last login:August 19, 2025, 09:11:17 pm
« Reply #5 on: August 18, 2025, 06:34:14 am »
Did you see this thread? It may help later on in the thread it has model 2 outputs if I recall.
https://forum.arcadecontrols.com/index.php/topic,167200.0/all.html
Endprodukt
« Reply #6 on: August 19, 2025, 10:05:12 am »
Now I do. :D No luck with Sega Rally so far.
buttersoft
  • Last login:Yesterday at 03:34:35 am
  • Is running at 15kHz
« Reply #7 on: August 19, 2025, 07:45:04 pm »
Endprodukt
« Reply #8 on: Yesterday at 03:37:25 am »
See my post in the m2emu networking thread - https://forum.arcadecontrols.com/index.php/topic,133283.msg1778844.html#msg1778844
Who would have guessed you need several dll files haha, convenient. I made them change through AHK when I launch a specific game. Do you have output on sgt24 and over rev?
I recommend you to use ffb through ffb plug-in at least for the games it works on as it fixed some problems. Still not perfect.
