Author Topic: GroovyArcade vertical mode  (Read 4554 times)
dynamic_duo
  • Last login:April 14, 2025, 03:39:20 pm
« on: March 28, 2025, 02:53:26 pm »
I created two emulators:
MAME and Vertical MAME for shooters (both groovymame)
How do I switch to vertical mode for shooters, as well as the menu, if possible?
Ben from  Paris
Substring
  • Last login:Yesterday at 03:36:36 am
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
Re: GroovyArcade vertical mode
« Reply #1 on: March 30, 2025, 04:35:07 pm »
Salut,
I can't say groovyarcade is set to go on a rotating cab, even if sme people could do it with some scripting. At least, the configuration is easy if you just want a vertical cab, but looks like it doesn't suit your needs ?
dynamic_duo
« Reply #2 on: April 14, 2025, 03:39:20 pm »
You are right, I preferred to create two separate systems.
Ben from  Paris
