Author Topic: Looking for some help configuring American Laser games in Singe  (Read 11084 times)
purbeast
  • Last login:June 19, 2026, 11:39:50 am
I just grabbed Hypseus Singe to put in my light gun cab.
I kind of understand how to setup the controls in the .ini file but I am not sure if I am doing it right or not.
When I used the little cool (the red UI that spits out the inputs for you), I used that to help set the X and Y axis in the default hypinput.ini file.
I got the -002 for the Up, +001 for down, -001 for left, and +001 for right.
So I added those to the KEY_UP, KEY_DOWN, KEY_LEFT, and KEY_RIGHT settings.
However, all it is really doing is moving the cursor around in the direction I am pointing.
So if I aim the gun to the right, the cursor just starts moving right.  Then it hit me that this is basically acting like a dpad moving the cursor around the screen.
Is there anyway to make this more like an actual analog stick or does that just not work?  I know Sinden guns work in this game so I'd assume there is a way to do it, but I am just not sure since the control setup is not very straight forward at all.
I also never had any luck getting the trigger buttons set properly, even though on that utili I see the on screen is 001 and the offscreen is 002, and I tried setting that in the ini file as well but just did not have luck with that either.
PaCiFiKbAllA
  • Last login:February 14, 2026, 07:59:18 pm
  • ...currently in the matrix...
Re: Looking for some help configuring American Laser games in Singe
« Reply #1 on: March 18, 2025, 07:22:13 pm »
Might want to join the Hypseus Singe Discord then.  The devs on there are active.
purbeast
« Reply #2 on: March 18, 2025, 07:56:20 pm »
Thanks yeah I actually found it after I posted on here about it and have posted a question on there as well.
If I get any updated info on how to do it if it's possible, I will pass it along.
