Author Topic: SHOWDOWN LAN  (Read 4529 times)
alexwstl
  • Last login:February 17, 2025, 11:53:49 am
SHOWDOWN LAN
« on: January 24, 2025, 11:13:49 am »
Have anyone had any luck with this game? It’s a really fun game and would love to get LAN working. Others have said it works and its very similar to GRID and RALLY 3, but it doesn’t seem to be pulling the ini files, I’m sure it’s a directory issue but I can’t figure it out. If someone can share their setup I would really appreciate it. hanks again!
Zeosstud
  • Last login:July 17, 2026, 03:06:09 pm
Re: SHOWDOWN LAN
« Reply #1 on: January 24, 2025, 04:42:17 pm »
That is one of the games that Teknoparrot says works via LAN.. Have you tried that??
Fursphere
  • Last login:July 27, 2026, 09:16:36 pm
Re: SHOWDOWN LAN
« Reply #2 on: January 24, 2025, 05:20:21 pm »
There doesn't appear to be anything in the TeknoParrot config for LAN and this game.  So it might be outside of TK in INI files.  Which may or may not work if you launch the game through TK.
I'll see if I can get it going on my twin cab this weekend if I have time.
holmes
  • Last login:May 18, 2026, 02:22:10 am
Re: SHOWDOWN LAN
« Reply #3 on: January 26, 2025, 04:23:02 am »
Hi,
LAN playing is working for this game on my twin racer.
In directory ShellData, file ShellData.ini, enable Network and attribute a number to each cabinet
Code: [Select]
[System]
Version=3
ClearRequired=0
[Credit]
Freeplay=1
EntryType=0
[Audio]
MusicVolume=100
SFXVolume=100
VoiceVolume=100
AttractMusic=0
[CalibrationData]
AccelUp=83
AccelDown=214
BrakeUp=35
BrakeDown=188
SteeringLeft=12
SteeringRight=236
FeedbackStrength=2
SteeringCentre=123
[Motionbase]
GlobalEnable=1
Strength=2
[Network]
CabinetID=2
Enabled=1
[Timers]
spMpTimeLimit=8
spTourTimeLimit=8
mpWaitingForChallengersTimeLimit=10
nameEntryTimeLimit=20
eventSelectTimeLimit=20
vehicleSelectTimeLimit=14
liverySelectTimeLimit=14
resultsTimeLimit=6
leaderboardTimeLimit=6
tourProgressTimeLimit=8
tourProgressRetryTimeLimit=18
netResultsTimeLimit=6
In directory Shell, file Game.ini, activate Network and give corresponding IP adress for each cabinet
Code: [Select]
[CabinetSKU]
ExternalKeypad=1
ExternalScreen=1
DefaultView=0
[Motionbase]
COMPort=3
ZeroLimit=5000
MaxSpeed=250000
ParkSpeed=30000
Maxpos=70000
Maxtorque=90
Scale=1300
RumbleScale=14000
BoostScale=15000
Hysteresis=0
Accel=10000
Frametime=16
DisableESTOP=0
[Telemetry]
Inverted=0
Smoothing=4
Source=1
[Configuration]
CalibrationLeft=10
CalibrationRight=26
[Window]
Fullscreen=1
Width=0
Height=0
[Graphics]
RestartAttempts=5
Adapter=0
Refresh=60
[System]
Debug=0
Version=1.2.9
[Sound]
Enabled=1
Primary=1
Volume=100
[Variables]
Directory=c:\sega\shell\variables
hiscorename1=..\Showdown\win\DataCache\shell\LeaderboardData2.xml
[Network]
Active=1
CabinetActive=1
Domain=192.168.1
BaseAddr=0
Port=18888
CabinetDomain=192.168.1
CabinetBaseAddr=5
CabinetPort=1234
MasterTimeout=15000
ClientTimeout=15000
[QRCode]
Directory=c:\sega\shelldata
Encrypted=1
Website=www.segascores.com
Game=DSD
In directory Launcher, file Launcher.ini put the path of the shell directory
Code: [Select]
[system]
version=1.2.0
ShellDirectory=D:\games\CoinOPS Next 2 Arcade\collections\Ringedge\roms\Sega DiRT Showdown\shell
window=0
screen_x=1920
screen_y=1080
[Logging]
LogEvents=FALSE
I made these modifications after looking for each ini file. Not sure if all these modifications are required. Worked at first try for me.
Good luck!
« Last Edit: January 26, 2025, 03:36:37 pm by holmes »
