Author Topic: Trouble mapping keys Retropie, Wii remote and Ultimate IO  (Read 4959 times)
clarky000
  • Last login:January 09, 2025, 01:42:16 am
« on: September 12, 2024, 06:37:02 pm »
So Im trying to set up a Wii remote with dolphine bar. Setup is
Retropie on an RPie 4
Ultimarc ultimate IO just using default config
2x Ultrastik 360s (plugged direct into the pie)
The issue Im having is that when I configure the buttons on the Wii remote as shown in most video tuturials ( for example) it overrides the button controls already mapped for P1 Start and P1 Select. If I set up the Wii by following the guides the first thing to do in Emulation station is configure input and set Start (key volume up) and Select (key volume down). If I do that the previously configured buttons (the ones next to my joystick) no longer work as they were set to Start (1) and Select (5).
 Im trying to work out if I can run both the controls I have for standard joystick games AND the Wii similtaniously.
Is this possible?
