Author Topic: Philips 28PT44060 (L01) - Pincushion issue.  (Read 2815 times)
arcadeswede
  • Last login:February 15, 2025, 10:03:44 am
    • Revansch!
« on: August 28, 2024, 08:02:56 am »
Hello!
I'm working on a Philips 28PT44060 (L01) that has a "pincushion issue".
Service manual/Schematics are here, start around page 26:
Philips 28PT44060 (L01) Service Manual
Story is... my friend came over with his TV. He had no audio in left speaker. I plugged it in, but it had sound in all speakers. He had the wrong cable or something when he tested. I wanted to try RGB on it so I plugged in my Mister with the proper VGA to SCART cable (75ohm temination and such), turned it on. Nothing.... tried a few times and eventually it turned on, but now with this pincushion issue:
I'm suspect that this issue lies within the E/W correction circuit, so that's where I've been troubleshooting. I found a MOSFET (7400) that was bad between Source (+) and Gate (-), and I couldn't turn it on with the multimeter trick, faulty indeed.
This MOSFET amplifies the E/W circuit I think?
There's alot of good testpoint so I've been using my somewhat cheap portable oscilloscope to compare with these.
As you can see, before and after the MOSFET swap the Vpp of L4 changed but schematic says around 12-13Vpp, I get 10Vpp. And from here I don't know where to look. The Gate of the MOSFET have 3.9V so it's almost at it's max which is 4V on the Threshold so it sure is open. From what I can recall, after changing the MOSFET the pincushion was still the same amount. This confuses me...
There's no E/W correction or Parabola parameters in the service menu on this model.
Here are some measurements I did:
Any help would be very appreciated and I have done alot of components test to verify the state that I can answer to later!
Thanks in advance!
//Victor
« Last Edit: August 28, 2024, 09:43:40 am by arcadeswede »
