Author Topic: Scan Converter Options  (Read 2708 times)
Rocketeer2001
  • Last login:December 30, 2024, 01:35:31 am
  • Working on Arcades and drinking Lemonade
« on: July 19, 2024, 09:00:58 pm »
I'm looking for a scan converter to convert medium resolution 25kHz / 60Hz signal from a 15D VGA arcade board to a standard resolution 15kHz / 60Hz as RGBs. I'm trying to use a normal TV with my arcade board, but would like to get the best image I can at a reasonable price.
I've found two old business grade devices that can maybe do this:
1. AVerMedia AVerKey iMicro PC/Mac to TV Scan Converter
2. TView Gold PC-to-TV Converter
The Averkey was going to be my choice originally as its specs list my input resolution as one it can accept, it is simply plug and play, and has a VGA style output that is supposed to be for RGB SCART. What I don't know is if it will output that SCART signal as 50Hz (per the SCART standard) or if it'll match the input signal which is 60Hz.
The TView Gold also has an RGB output via a weird 9-pin S-video port, and it has a PAL/NTSC switch so you get to force whichever timing you want (50Hz or 60Hz). What the specs don't tell me is if it'll accept a 25kHz signal, and if I need to install the software that comes with the device. I suspect the software is just for adding features to the PC the device is connected to, like using the remote as a laser pointer and plopping fonts onto a presentation or whatever.
Both are somewhat of a mystery to me, but I thought maybe someone has had some experience with these before and can chime in.
I know the Extron scan converters are likely the best, but they're still a little pricey, even the VSC 500.
Rocketeer2001
Re: Scan Converter Options
« Reply #1 on: August 11, 2024, 12:15:03 am »
I got the AVerkey after speaking with a fella from Averkey Tech Support. He confirmed that if your input signal is 60Hz, you'll get 60Hz out of any of the outputs including the SCART port.
This unit will also save any settings your fiddle with after you power cycle it, and it turns on by itself as soon as it has power.
If you want to use the RGB output, you need to wire up a SCART connector to a VGA cable. The pinout should be similar to a typical VGA connector. Found this post where the guy says a couple pins are different:
https://forum.arcadecontrols.com/index.php/topic,3278.msg19397.html#msg19397
He said:
The Averkey has a very funky connector labeled "RGB" that is identical to VGA except for the following:
pin 4: RGB=NC, VGA=ground
pin 9: RGB=select PAL, VGA=NC
pin 15: RGB=compos sync, VGA=NC
