Author Topic: groovymame super resolutions are stretched horizontally  (Read 3351 times)
darknezz19
  • Last login:June 14, 2025, 01:16:12 pm
« on: June 26, 2024, 06:34:50 pm »
For some reason groovymame is displaying super resolutions it would seem in their 2560 horizontal resolution stretched out. Have gone over my mame.ini and looks correct. It's like GM isn't scaling down the super resolution to fit. They display fine in ArcadeOSD though.
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini;ini/presets
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
swpath                    software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
share_directory           share
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
rewind                    0
rewind_capacity           100
playback
record
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  auto
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
syncrefresh               0
syncaudio                 1
lowlatency                1
framedelay                0
vsync_offset              0
black_frame_insertion     0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
fallback_artwork
override_artwork
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_dot_size             1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
compressor                1
speaker_report            0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  1
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0
joystick_saturation       0.85
joystick_threshold        0.3
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            joystick
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           joystick
positional_device         keyboard
mouse_device              keyboard
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
debuglog                  0
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
comm_framesync            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
language
nvram_save                1
# SCRIPTING OPTIONS
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# OSD INPUT MAPPING OPTIONS
uimodekey                 auto
controller_map            none
background_input          0
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_port             23946
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
waitvsync                 1
sync_mode                 2
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    3:4
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
switchres_ini             0
switchres_backend         auto
modesetting               0
modeline_generation       1
monitor                   custom
interlace                 1
doublescan                0
super_width               2560
changeres                 1
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
h_size                    1
h_shift                   0
v_shift                   0
v_shift_correct           0
pixel_precision           1
sync_refresh_tolerance    2.0
interlace_force_even      0
autosync                  1
autofilter                1
autostretch               1
scale_proportional        1
dri_device                auto
screen_compositing        0
screen_reordering         0
allow_hw_refresh          0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                15450-16050, 50.00-65.00, 3.910, 4.700, 6.850, 0.190, 0.191, 1.018, 0, 0, 192, 288, 448, 576
crt_range1                23900-24900, 50.00-65.00, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 320, 384, 0, 0
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
mister_ip                 0.0.0.0
mister_compression        none
mister_window             0
mister_fd_margin          1.5
mister_interlaced_fb      1
# OSD ACCELERATED VIDEO OPTIONS
filter                    1
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# OSD MIDI OPTIONS
midiprovider              auto
# OSD EMULATED NETWORKING OPTIONS
networkprovider           auto
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains
bgfx_avi_name             auto
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
attach_window
# DIRECT3D POST-PROCESSING OPTIONS
hlslpath                  hlsl
hlsl_enable               0
hlsl_oversampling         0
hlsl_write                auto
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
distortion                0.0
cubic_distortion          0.0
distort_corner            0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_variation        1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
chroma_mode               3
chroma_conversion_gain    0.299,0.587,0.114
chroma_a                  0.64,0.33
chroma_b                  0.30,0.60
chroma_c                  0.15,0.06
chroma_y_gain             0.2126,0.7152,0.0722
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_beam_smooth        0.0
vector_length_scale       0.5
vector_length_ratio       0.5
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.0
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.06
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.01
lut_enable                0
ui_lut_enable             0
# FULL SCREEN OPTIONS
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
dual_lightgun             0
orientation               horizontal
Tried super_width set to '2560' and also '2560x0' but it's the same result. Have googled all day but not run into someone with this problem. Running groovymame_0265.220c_win-7-8-10
« Last Edit: June 26, 2024, 06:36:56 pm by darknezz19 »
darknezz19
Re: groovymame super resolutions are stretched horizontally
« Reply #1 on: June 27, 2024, 03:18:46 pm »
Whoops. Here is the log.
MK3FANATIC
  • Last login:November 08, 2025, 08:56:50 am
« Reply #2 on: June 28, 2024, 02:45:53 pm »
try changing aspect to 4:3 or auto instead of 3:4 in your mame.ini
darknezz19
« Reply #3 on: June 29, 2024, 04:07:24 am »
Thanks for the suggestion mk3fanatic. That wasn't the issue though unfortunately. Guess I'm just going to use native resolutions and adjust H porches as needed. Tried for days to get this issue figured out.
