Author Topic: Strange game speed issue  (Read 3093 times)
Dudeman
  • Last login:April 23, 2025, 06:42:24 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
« on: June 24, 2024, 09:15:32 pm »
Windows 10, Groovymame .240, old Sony Trinitron monitor.
If I RDP to the machine and run Elevator Action via command line or through my front end, it seems to be fine. If I go to my cabinet and run it on the TV it screams... as in game is running over 700%. Some other games are fine... like 19XX.
Any help would be greatly appreciated.
Here's the log from the RDP session:
Code: [Select]
Attempting load of mame.ini
Parsing mame.ini
Parsing mame.ini
Attempting load of horizont.ini
Parsing horizont.ini
Attempting load of arcade.ini
Attempting load of raster.ini
Parsing raster.ini
Attempting load of source\taitosj.ini
Attempting load of elevator.ini
Parsing elevator.ini
Starting plugin data...
Parsing mame.ini
Parsing mame.ini
Parsing raster.ini
Video: Monitor 65537 = "\\.\DISPLAY177" (primary)
Using Windows OpenGL driver
Switchres(v2.002) add display[0]
Switchres: display[0] options: monitor[custom] generation[on]
Switchres: Monitor range 15625.00-15750.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,192,288,448,576
Switchres: \\.\DISPLAY177: Microsoft Remote Display Adapter (RdpIdd_IndirectDisplay)
Switchres: Device key:
Video chipset is not compatible.
Switchres: Searching for custom video modes...
Switchres: [  0] 2560x1080 @ 32p* : system mode
system mode
Switchres: Found 0 custom of 0 active video modes
Switchres: get_mode(0) 341 224 60.000000 1.333333
Switchres: Calculating best video mode for 341x224@60.000000 orientation: normal
Switchres: [2560]x[1080]_[32=32.000000Hz]
   rng(0):  out of range
Physical width 2560, height 1080
OpenGL: ATI Technologies Inc.
OpenGL: AMD Radeon HD 6450
OpenGL: 4.5.13417 Compatibility Profile Context 0
OpenGL: texture rectangle supported
OpenGL: non-power-of-2 textures supported (new method)
OpenGL: vertex buffer supported
OpenGL: pixel buffers supported
OpenGL: framebuffer object supported
OpenGL: GLSL supported
OpenGL: max texture size 16384 x 16384
Leave renderer_ogl::create
RawInput: APIs detected
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Input: Adding keyboard #0:
Input: Adding keyboard #1:
Input: Adding keyboard #2:
Input: Adding keyboard #3:
Input: Adding keyboard #4:
Input: Adding keyboard #5:
Input: Adding keyboard #6:
Input: Adding keyboard #7:
Input: Adding keyboard #8:
Input: Adding keyboard #9:
Input: Adding keyboard #10:
Input: Adding keyboard #11: HID Keyboard Device (device id: \\?\HID#VID_413C&PID_2005#6&d24d029&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #12: HID Keyboard Device (device id: \\?\HID#VID_046D&PID_C517&MI_00#7&21874170&0&0000#{884b96c3-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding keyboard #13:
Input: Adding mouse #0:
Input: Adding mouse #1:
Input: Adding mouse #2:
Input: Adding mouse #3:
Input: Adding mouse #4:
Input: Adding mouse #5:
Input: Adding mouse #6:
Input: Adding mouse #7:
Input: Adding mouse #8:
Input: Adding mouse #9:
Input: Adding mouse #10:
Input: Adding mouse #11: HID-compliant mouse (device id: \\?\HID#VID_413C&PID_301A#6&156010c5&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #12: HID-compliant mouse (device id: \\?\HID#VID_046D&PID_C517&MI_01&Col01#7&394acdb5&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding mouse #13:
Input: Adding lightgun #0:
Input: Adding lightgun #1:
Input: Adding lightgun #2:
Input: Adding lightgun #3:
Input: Adding lightgun #4:
Input: Adding lightgun #5:
Input: Adding lightgun #6:
Input: Adding lightgun #7:
Input: Adding lightgun #8:
Input: Adding lightgun #9:
Input: Adding lightgun #10:
Input: Adding lightgun #11: HID-compliant mouse (device id: \\?\HID#VID_413C&PID_301A#6&156010c5&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #12: HID-compliant mouse (device id: \\?\HID#VID_046D&PID_C517&MI_01&Col01#7&394acdb5&0&0000#{378de44c-56ef-11d1-bc8c-00a0c91405dd})
Input: Adding lightgun #13:
unzip: opened archive file D:\LaunchBox\Games\Arcade\elevator.zip
unzip: found D:\LaunchBox\Games\Arcade\elevator.zip ECD
unzip: D:\LaunchBox\Games\Arcade\elevator.zip has no ZIP64 ECD locator
unzip: read D:\LaunchBox\Games\Arcade\elevator.zip central directory
unzip: closing archive file D:\LaunchBox\Games\Arcade\elevator.zip and sending to cache
unzip: found D:\LaunchBox\Games\Arcade\elevator.zip in cache
unzip: opened archive file D:\LaunchBox\Games\Arcade\m68705p5.zip
unzip: found D:\LaunchBox\Games\Arcade\m68705p5.zip ECD
unzip: D:\LaunchBox\Games\Arcade\m68705p5.zip has no ZIP64 ECD locator
unzip: read D:\LaunchBox\Games\Arcade\m68705p5.zip central directory
unzip: closing archive file D:\LaunchBox\Games\Arcade\m68705p5.zip and sending to cache
Optional I/O port ':GEARP2' not found
Optional I/O port ':GEARP1' not found
Optional shared pointer ':kikstart_scroll' not found
Optional memory region ':screen' not found
Starting Elevator Action (BA3, 4 PCB version, 1.1) ':'
  (missing dependencies; rescheduling)
Starting Zilog Z80 ':maincpu'
Starting Zilog Z80 ':audiocpu'
Starting Video Screen ':screen'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Speaker ':speaker'
Starting Input Merger (all high) ':soundnmi1'
Starting Input Merger (any high) ':soundnmi2'
Starting AY-3-8910A PSG ':ay1'
Starting AY-3-8910A PSG ':ay2'
Starting AY-3-8910A PSG ':ay3'
Starting AY-3-8910A PSG ':ay4'
Starting Watchdog Timer ':watchdog'
Starting 8-Bit R-2R DAC ':dac'
Starting Discrete Sound ':dacvol'
Starting Taito SJ Security MCU Interface ':bmcu'
Starting Motorola MC68705P5 ':bmcu:mcu'
Attempting to parse: default.cfg
Attempting to parse: elevator.cfg
OpenGL: VBO supported
OpenGL: PBO supported
OpenGL: FBO supported
OpenGL: GLSL using shader filter 'bilinear', idx: 1, num 1 (vid filter: 0)
GL texture: copy 1, shader 1, dynamic 0, 256x224 256x224 [PALETTE16, Equal: 0, Palette: 1,
            scale 1x1, border 0, pitch 256,256/16384], bytes/pix 4
Average speed: 97.60% (3 seconds)
Sound: buffer overflows=2 underflows=0
Switchres: exit
And here's the log when I use the TV as a screen:
Code: [Select]
Parsing mame.ini
Parsing mame.ini
Parsing raster.ini
Parsing mame.ini
Parsing mame.ini
Parsing raster.ini
Video: Monitor 65537 = "\\.\DISPLAY1" (primary)
Switchres: \\.\DISPLAY1: AMD Radeon HD 6450 (PCI\VEN_1002&DEV_6779&SUBSYS_E164174B&REV_00)
Switchres: Device key: System\CurrentControlSet\Control\Video\{1A95CDDB-F72C-11ED-85F4-448A5B9E381C}\0000
ATI/AMD ADL init
AMD driver version 15.8(patched)
ADL functions retrieved successfully.
Switchres: [  0]  256x 224 @ 30i : system mode
Switchres: [  1]  256x 240 @ 30i : system mode
Switchres: [  2]  320x 240 @ 30i : system mode
Switchres: [  3]  352x 224 @ 30i : system mode
Switchres: [  4]  368x 240 @ 30i : system mode
Switchres: [  5]  384x 240 @ 30i : system mode
Switchres: [  6]  640x 480 @ 60i : AMD ADL timing "640x480_60i 15.679000KHz 59.957935Hz" 13.030000 640 666 727 831 480 483 489 523 interlace  -hsync -vsync
Switchres: [  7]  640x 480 @ 30i* : AMD ADL timing "640x480_30i 15.805000KHz 59.981026Hz" 13.150000 640 664 728 832 480 482 485 527 interlace  -hsync -vsync
Switchres: [  8] 2560x 224 @ 60p : AMD ADL timing "2560x224_60 15.901000KHz 60.003773Hz" 52.920000 2560 2680 2896 3328 224 233 234 265   -hsync -vsync
Switchres: [  9] 2560x 240 @ 60p : AMD ADL timing "2560x240_60 15.898000KHz 59.992455Hz" 52.400000 2560 2680 2872 3296 240 242 244 265   -hsync -vsync
Switchres: [ 10] 2560x 480 @ 60i : AMD ADL timing "2560x480_60i 15.958000KHz 59.992481Hz" 52.600000 2560 2720 2824 3296 480 485 498 532 interlace  -hsync -vsync
Switchres: Found 5 custom of 10 active video modes
Switchres: [ 256]x[ 224]_(30=30.000000Hz) - locked
Switchres: [ 256]x[ 240]_(30=30.000000Hz) - locked
Switchres: [ 320]x[ 240]_(30=30.000000Hz) - locked
Switchres: [ 352]x[ 224]_(30=30.000000Hz) - locked
Switchres: [ 368]x[ 240]_(30=30.000000Hz) - locked
Switchres: [ 384]x[ 240]_(30=30.000000Hz) - locked
Switchres: [ 640]x[ 480]_(60=59.957935Hz)
   rng(0):  640 x 480_60.000000i 15.690000 [fract] scale(1, 2, 1) diff(46.25, 0.00, 0.0000) ratio(1.860, 2.143)
Switchres: [ 640]x[ 480]_[30=59.981026Hz]
   rng(0):  640 x 480_59.981026i 15.805000 [fract] scale(1, 2, 1) diff(46.25, 6.67, -0.0190) ratio(1.860, 2.143)
Switchres: [2560]x[ 224]_(60=60.003773Hz)
   rng(0): 2560 x 224_60.000000p 15.660000 [integ] scale(7, 1, 1) diff(5.94, 0.00, 0.0000) ratio(7.442, 1.000)
Switchres: [2560]x[ 240]_(60=59.992455Hz)
   rng(0): 2560 x 240_60.000000p 15.660000 [integ] scale(7, 1, 1) diff(5.94, 0.00, 0.0000) ratio(7.442, 1.071)
Switchres: [2560]x[ 480]_(60=59.992481Hz)
   rng(0): 2560 x 480_60.000000i 15.690000 [integ] scale(7, 2, 1) diff(5.94, 0.00, 0.0000) ratio(7.442, 2.143)
Switchres: normal (341x224@60.000000)->(2560x224@60.000000)
Switchres: Modeline "2560x224_60 15.660000KHz 60.000000Hz" 52.085160 2560 2664 2909 3326 224 234 237 261   -hsync -vsync
Switchres: updated AMD ADL timing "2560x224_60 15.660000KHz 60.000000Hz" 52.085160 2560 2664 2909 3326 224 234 237 261   -hsync -vsync
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -nounevenstretch
SwitchRes: Setting option -unevenstretchx
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -nofilter
Physical width 640, height 480
OpenGL: 4.5.13417 Compatibility Profile Context 15.301.1901.0
Average speed: 764.98% (36 seconds)
Sound: buffer overflows=1589 underflows=0
Switchres: exit
Switchres: success updating mode AMD ADL timing "2560x224_60 15.901000KHz 60.003773Hz" 52.920000 2560 2680 2896 3328 224 233 234 265   -hsync -vsync
ATI/AMD ADL close
« Last Edit: June 24, 2024, 09:17:25 pm by Dudeman »
Dudeman
Re: Strange game speed issue
« Reply #1 on: June 24, 2024, 09:16:31 pm »
I figure I should include my mame.ini:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
homepath                  .
rompath                   D:\LaunchBox\Games\Arcade
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini;ini/presets
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
swpath                    software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
share_directory           share
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
rewind                    0
rewind_capacity           100
playback
record
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  auto
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             1
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              0
syncrefresh               0
syncaudio                 1
lowlatency                1
framedelay                0
vsync_offset              0
black_frame_insertion     0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             0
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
fallback_artwork
override_artwork
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_dot_size             1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
compressor                1
speaker_report            0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             mouse
adstick_device            keyboard
pedal_device              keyboard
dial_device               mouse
trackball_device          mouse
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   1
log                       1
oslog                     0
debug                     0
update_in_pause           0
debugscript
debuglog                  0
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
comm_framesync            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
language
nvram_save                1
# SCRIPTING OPTIONS
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
# HTTP SERVER OPTIONS
http                      0
http_port                 8080
http_root                 web
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_port             23946
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     opengl
numscreens                1
window                    0
maximize                  1
waitvsync                 0
sync_mode                 2
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    \\.\DISPLAY2
aspect                    4:3
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
switchres_ini             0
switchres_backend         auto
modesetting               0
modeline_generation       1
monitor                   custom
interlace                 1
doublescan                0
super_width               2560
changeres                 1
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
v_shift_correct           0
pixel_precision           1
sync_refresh_tolerance    2.0
interlace_force_even      0
autosync                  1
autofilter                1
autostretch               1
screen_compositing        0
screen_reordering         0
allow_hw_refresh          0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                "15625-15750, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576"
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   1
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2
# PORTAUDIO OPTIONS
pa_api                    none
pa_device                 none
pa_latency                0
# BGFX POST-PROCESSING OPTIONS
bgfx_path                 bgfx
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_lut
bgfx_avi_name             auto
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
attach_window
# DIRECT3D POST-PROCESSING OPTIONS
hlslpath                  hlsl
hlsl_enable               0
hlsl_oversampling         0
hlsl_write                auto
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
distortion                0.0
cubic_distortion          0.0
distort_corner            0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_variation        1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   0.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.0
offset                    0.0,0.0,0.0
scale                     1.0,1.0,1.0
power                     1.0,1.0,1.0
floor                     0.0,0.0,0.0
phosphor_life             0.0,0.0,0.0
chroma_mode               3
chroma_conversion_gain    0.299,0.587,0.114
chroma_a                  0.64,0.33
chroma_b                  0.30,0.60
chroma_c                  0.15,0.06
chroma_y_gain             0.2126,0.7152,0.0722
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_beam_smooth        0.0
vector_length_scale       0.5
vector_length_ratio       0.5
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.0
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.06
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.01
lut_texture
lut_enable                0
ui_lut_texture
ui_lut_enable             0
# FULL SCREEN OPTIONS
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
Dudeman
« Reply #2 on: June 24, 2024, 09:43:48 pm »
Well... after wasting your time and mine with this post I found someone with a similar issue. I swear I did every keyword search I could think of and didn't find this dude's post about Gauntlet running and 4x.
He said setting syncrefresh to 0 in a game specific ini despite it being in the mame.ini worked for him.
Worked for me too.
I also saw where he moved to v265. I'm hesitant to do that as I don't want to have to update all my rom files too. That's a PITA.
haynor666
  • Last login:July 15, 2025, 03:41:34 pm
  • retro maniac
« Reply #3 on: July 17, 2024, 05:36:21 am »
Elevator Action should be ok even in older version. Fix mentioned is for Midway 3D games that did not sync correctly.
Calamity
  • Moderator
  • Last login:July 01, 2025, 01:29:14 pm
  • Quote me with care
« Reply #4 on: July 17, 2024, 07:14:34 am »
Dudeman,
By looking at your logs and .ini, the problem in the first place is that you switched to video opengl, which doesn't support vsync on GroovyMAME.
Set video d3d instead.
Steps to create a log:
