Author Topic: Arcade Encoder that can switch to analog and digital with a push of button  (Read 3011 times)
Nitro0602
  • Last login:June 29, 2025, 12:27:52 am
Hey guys!
Any encoders that can do that? Similar to the Mayflash f300/400 joysticks where you slide it to x/y?
I was hoping there’s one that had a mode button where you just push it and switches between the two?
  • Last login:Yesterday at 09:46:10 pm
I don't see a mode switch, but maybe this one will work?   :dunno
https://www.amazon.com/SJ-JX-Encoder-Board-Microswitch-Button-Analog/dp/B08J47Y4X4/?th=1
If you have a ZD encoder, mimregi mentioned this Instructable that claims to make it true analog, but couldn't confirm that it works because he had a different version of the board.
https://www.instructables.com/Zero-Delay-USB-Encoder-True-Analog-Joystick-Modifi/
baritonomarchetto
  • Last login:Yesterday at 01:15:19 am
Easy task with arduino leonardo/pro micro or raspberry pi pico
  • Last login:July 13, 2025, 08:27:50 pm
I do it with a minimus AVR and a toggle switch.  Mapping stays identical but the joystick goes from analog to digital input.  There’s no fidelity, it’s just maximum throw in analog mode, but it’s fine for most games.
