Author Topic: Saving the Maintain Aspect Ratio setting  (Read 1744 times)
TheRetroCarrot
  • Last login:July 26, 2024, 10:32:36 am
« on: May 13, 2024, 04:49:08 pm »
I'm trying to disable this setting globally or on a per game basis as I'm using super resolutions on a 240p display. I have keep aspect ratio set to 0 in the mame.ini which seems to do nothing. The maintain aspect ratio setting does not save on a per game basis, the aspect ratio is only correct if this is disabled.
Is there something I can put in the .cfg for each game, or something I'm missing to globally disable this?
Thank you.
EDIT: I got this to work on a per game basis, had my ini files in the wrong spot. Just for some reason I can't get it working globally. Not a big deal but if anyone has an idea it'd save me making a file for every single game I add.
« Last Edit: May 13, 2024, 08:36:21 pm by TheRetroCarrot »
