Author Topic: PIN not found.  (Read 11837 times)
Tibere
  • Last login:May 29, 2024, 08:07:44 am
PIN not found.
« on: May 10, 2024, 06:51:24 am »
I bought a VORTEX JVL TOUCH MATE (iTOUCH 9) ;D .
I wanted to change some settings, but I need a PIN and where I bought it is a recycling store and no one knows the old PIN  :'( .
Is there a universal PIN so I can change settings?
Please if anyone can tell me the PIN code I would be very grateful.
Thank you very much and sorry for my bad English.
lilshawn
  • Moderator
  • Last login:May 30, 2026, 07:21:17 pm
Re: PIN not found.
« Reply #1 on: May 18, 2024, 02:12:38 pm »
other than trying random things like "0000" "1111" "1234" there was no default code... JVL had no code originally so someone put one on there.
you'll have to reset the system to clear out the code...as it's stored in the IO board. you'll have to remove the battery on it to clear the memory in it (difficult in this machine, as it's soldered in place.)... then boot it up and reset or reinstall the software to original state to totally clear it out and start fresh.
there is a good chance your IO board is going to need the battery replaced anyway... now is a good time to do it.
that said, if someone who owned this machine had megatouch machines too, they may have reused the code from that to keep them the same...the code for those is "4123" and older ones "4777"
if you do manage to get in, you can clear out the code, or change it to something you will remeber.
Tibere
Re: PIN not found.
« Reply #2 on: May 27, 2024, 10:17:24 am »
Sorry for the delay in responding friend.
Well, as soon as I have time I will try to do what you said.
For now, thank you very much for your help.
As soon as I find something I will post the results here again.
Thank you very much :)
