Author Topic: New Project - Where to start  (Read 9120 times)
beerbarrel
  • Last login:October 18, 2025, 07:00:48 am
« on: January 22, 2024, 08:12:25 am »
Picked up these two arcade cabs recently. They are wired for jamma and contain standard arcade monitors. I want to make one of them a mame machine just for older arcade games. Both of the machines work as is and the monitors work and have zero screen burn. At first I thought about replacing the monitors with a flat screen monitor but them decided against it. I guess my question is as follows: If I install of of the Jpac style cards and use a pc for mame will I be able to retain the 15khz monitor? Or is there a better option? If this is not the correct thread to post this please let me know.
thx
  • Last login:October 03, 2026, 11:32:04 am
Re: New Project - Where to start
« Reply #1 on: January 22, 2024, 08:30:46 am »
Just get a Pandora's Box with CGA output.  They're like $50.
beerbarrel
« Reply #2 on: January 22, 2024, 09:05:50 am »
Those look very interesting...thx. They might be the ticket I need.
mourix
  • Last login:October 02, 2026, 08:02:19 am
« Reply #3 on: January 22, 2024, 09:29:19 am »
The Chinese Pandora boards are plug and play but the upsides kinda end there because the emulation is so horrible. I stopped playing mine as 90% of the game roms are hacked roms, duplicates or play like crap. Like when you play Sonic and find out it's the infinite lives one after a while.
I can recommend RGB-Pi or the compatible hardware if you want better and more accurate gameplay.
Personally, I went going with GroovyMAME and CRT Emudriver and an old office PC for the ultimate solution. It's just a lot of hardware hassle if you are not technical.
beerbarrel
« Reply #4 on: January 22, 2024, 09:49:11 am »
The rgb-pi looks very interesting as I have a few pi's lying around waiting for a job. I also have a few i5 nucs lying around too. They are what I would like to use. Lucky for me, my son has an IT job and they go and upgrade office systems for companies and they retire a lot of these nucs so I get them from time to time. I was thinking that I could use Mame with some sort of interface card to connect straight to the jamma harness that would also make use of the factory monitors.
mourix
« Reply #5 on: January 22, 2024, 01:48:47 pm »
That sounds like a nice couple of options then :) CRT Emudriver is what you need to get the proper arcade monitor signal out of a PC. Just do keep in mind it's AMD/ATI GPUs only.
beerbarrel
« Reply #6 on: January 23, 2024, 12:36:00 pm »
Due to the fact that I dont think these Intel Nucs have ATI graphics so that is an issue. I went ahead and ordered the jamma pi card. I have a spare  Pi5. I think Im going to give that a shot first....
thx guys
