Author Topic: Bolt pattern ?  (Read 1564 times)
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
Bolt pattern ?
« on: March 05, 2004, 09:11:51 am »
anyone here happen to know the bolt pattern for a happ P360 optical?
i thought its was 3" x 2.56" but im uncertain as CAD models i got from oscar controls conflict with this.
i have a stick at home i could check but im currently at work trying to workup a CP on Solidworks and i have no idea what the Bolt pattern is to mount this stick up.
ironically its not even on the instruction card provided with the stick (think happ should add this little piece of trivia for builders)
thx all!  ;D
Enjoying the fruits of technological obsolescence one game at a time...
OSCAR
    • Oscar Controls
Re:Bolt pattern ?
« Reply #1 on: March 05, 2004, 09:51:17 am »
The Happ sticks all use a 3" x 2.6" bolt pattern, same as drawn in my AutoCAD files.  The base of the P360 is basically the same as the old Wico bases, which is the same bolt pattern used on the Happ sticks.
TalkingOctopus
    • My Arcade
DYNAGOD
Re:Bolt pattern ?
« Reply #3 on: March 05, 2004, 10:15:04 am »
sweet..
when i imported and lined up your cad file with my control panel the mounting holes didnt line up .
when i tried to mate it up,even though it was only .080" off in total it was enough to cause all kind of assembly errors.
updating  CP to accomodate YOUR numbers.  ;D
Thx octopus,  that image should be linked to the product page, where did you find that?
« Last Edit: March 05, 2004, 10:15:50 am by DYNAGOD »
TalkingOctopus
    • My Arcade
Re:Bolt pattern ?
« Reply #4 on: March 05, 2004, 02:26:08 pm »
That is the diagram for the Super joystick.  But as previously stated, the Super has the same base as the P360 which has the same base as the ....
DYNAGOD
Re:Bolt pattern ?
« Reply #5 on: March 05, 2004, 02:36:21 pm »
ahhhh...
master of the obvious i am not  :P
again thx
TalkingOctopus
    • My Arcade
Re:Bolt pattern ?
« Reply #6 on: March 05, 2004, 03:36:56 pm »
ahhhh...
again thx
no it is not really all that obvious.  Happs website is not the greatest.
