Author Topic: Sound not working in Multicade 60-1 cocktail. Help?  (Read 3823 times)
TinyEvel
  • Last login:December 29, 2023, 12:58:39 am
« on: December 13, 2023, 10:12:52 pm »
Hi friends.
I recently acquired a 60-1 Multicade cocktail that looks like a professional build. Dated 2013.
I cannot get the sound to work.
I ran test mode when going through test prompts on screen the volume screen Volume is almost all the way up.
The tiny orange (volume?) knob on the circuit board is set to midpoint.
The knob on the power supply is set midway between L/R.
There are two speakers, the white wire from each speaker comes together then plugs into slot 10 on the Circuit board
The black wires from each speaker come together then connect to the L terminal on the back side of the 10 terminal on the circuit board.
When put my ear next to the speaker I can hear a hum so they are getting power. Just none of the game sounds are being sent to them.
Any thoughts?
Thanks.
lilshawn
Re: Sound not working in Multicade 60-1 cocktail. Help?
« Reply #1 on: December 14, 2023, 07:29:55 pm »
the amp runs on +12v if it is sketchy or missing it wont play sounds. the board only uses +5v, it doesnt care if it has no +12v.
check your chamma harness. your speaker connections should be the black and white wires (it looks like) 4 pins down from the +12v. i've had to pry out the contacts a little on those chamma harnesses to put more pressure on the edge connector to get a good connection.
feel the amp... see if it's hot. could indicate a short, or a failed speaker or failed amp IC... try another speaker on the output and see if anything plays. if the IC heatsink is cool...
try plugging some external computer speakers into the headphone jack (it's line out) and see if you have sound at all (you probably will here)
if you have sound out the headphone jack and everything else checks out... could be a failed amp. i've seen it a couple times. (maybe 3 times out of 100 machines) it's a standard part (like a TDA2030 or the like) and not too bad to replace. it runs about 15 or 20 bucks on sites like mouser or newark
DorkVonWaterfall
  • Last login:June 27, 2025, 09:35:13 am
« Reply #2 on: December 17, 2023, 06:48:49 am »
enjoy the sound in Gyruss and Gun Smoke :banghead: :angry:
« Last Edit: December 17, 2023, 07:02:47 am by DorkVonWaterfall »
