Author Topic: Groovyarcade 31khz with VGA CRT + Rotated configuration  (Read 2677 times)
archimage
  • Last login:May 23, 2024, 04:32:32 pm
« on: September 19, 2023, 10:20:08 am »
Hello,
I'm running Groovyarcade with 31khz, under Xorg and CRT VGA monitor, everything works fine on horizontal even deformed vertical games, but when rotating most games don't sync and give a black screen.
My rig is a mini pc with Ryzen 7 and Ati Vega RX 10 with an hdmi>vga adapter (ugreen).
Maybe i'm missing something that messes with vertical resolutions ?
Cheers
archimage
Re: Groovyarcade 31khz with VGA CRT + Rotated configuration
« Reply #1 on: September 20, 2023, 03:30:55 am »
Update :
I figured out some vertical games and some don't, for example all the cave/raizing work, but not the capcom/konami, it looks like some resolutions are not supported out of the box during the hdmi/vga conversion.
I already had a similar issue on Windows and needed to use EDID emulation to get over that, how is it possible to achieve that on Groovyarcade ?
Could be something totally different but i'm looking for workarounds
Also, is it possible to hack the bios to force 480p during boot / splash screen and setup sequences ?
It seems that the resolution is too high for 480p arcade monitors
Cheers
Substring
  • Last login:Today at 04:09:28 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
« Reply #2 on: October 01, 2023, 05:30:06 pm »
it turned out theproblem was with min dotclock not being set to 25.0
