Author Topic: Daisy chain LED buttons, what to do with the extra wires?  (Read 2026 times)
HeartOfDavid
  • Last login:September 23, 2023, 03:55:52 pm
« on: September 19, 2023, 08:43:15 am »
I have searched and searched and searched for the answer to this question. I bought a daisy chained wire kit and I'm left with several links at the end. I can't tell if I'm supposed to disconnect it or wrap them all up together in wire ties or electrical tape or something like that.
In the picture, you can see the four buttons wired in. I'm then left with 6 daisy chained connections in the wire that I'm not sure what to do. I know that this is a simple answer, but I want to make sure that I'm doing it correctly. What should I do?
  • Last login:Yesterday at 10:23:33 pm
Re: Daisy chain LED buttons, what to do with the extra wires?
« Reply #1 on: September 19, 2023, 03:55:38 pm »
This approach gives you more flexibility if you decide to change something on the panel like adding some admin buttons (Coin, Start, Pause, Exit, etc.) with LEDs.
- If you're concerned that the excess daisy chain might shift and short against something, you can cover the ends with a plastic bag or saran wrap and secure the covering with rubber bands, twist-ties, or electrical tape.
- You might want to use a "buddy tab" (fold the end of the tape over on itself) if you choose electrical tape so it's easy to unwrap.
If you're sure you won't want to add any more LED buttons, you can cut off the excess.
HeartOfDavid
« Reply #2 on: September 20, 2023, 10:19:02 am »
That is perfect, thank you!
