Author Topic: linux groovymame, replacing the mame with 2003 mame for older working titles  (Read 5564 times)
Deathblow81
  • Last login:March 04, 2026, 09:56:23 am
Noob question.......
Is it possible to replace the version of MAME found on Linux groovymame with the 2003 version for games like EX2, avp etc?
Thanks in advance
Calamity
  • Moderator
  • Last login:September 28, 2026, 10:32:04 am
  • Quote me with care
If you mean GroovyMAME in Groovyarcade, the answer is no.
You could do it through Retroarch with their 2003 core probably.
Steps to create a log:
Deathblow81
Thanks Calamity!
I got Groovyarcade working, just had problems with J-pac, then changed from retroarch to groovymame (FB I think?), then nothing worked.
I've changed strategy to updating rebuilding roms with CLRMamepro.
I'm going to do a fresh install of the live cd (Groovyarcade) then try rebuilt/updated ROMs.
I will bloody get there!
Deathblow81
Terrible question:
What version of Groovymame is being used? 0.257???
Deathblow81
I figured it out.... :notworthy:
ppriorfl
  • Last login:June 18, 2025, 02:18:49 pm
U wanna share?
I'm really struggling trying to get this all setup.  My last mame expererience was 20 years ago and on windows and a front end that isn't around anymore.
I'm trying to get the front end looking presentable with art work etc and the extras downloads and mame sets I am finding I'm not sure are compatible with what mame version is built in.
I've been searching to see if I can update mame from within groovy arcade but I can't figure that out either.
Substring
  • Last login:Yesterday at 02:40:28 pm
  • Forking GroovyArcade
    • forum.arcadecontrols.com/index.php/topic,160023.0.html
    • GroovyArcade active fork
In groovyarcade, just updating GM is a non sense, you have to go with a full update.
I encourage you to read the wiki, most of the answers to your questions are there
donluca
  • Last login:September 30, 2026, 03:34:33 pm
    • The 16-bit Audiophile Project
I don't remember if I pointed this out already... but have you guys thought about switching to Alpine Linux which has GroovyMAME in its own repositories, so it's just a matter of doing "apk upgrade"?
Substring
what is different with "apk update" insteaad of "pacman -Syu" ?
Alpine isn't worth, uses musl, big troubles ahead
donluca
Does Arch have GroovyMAME as well in its repositories?
If that's the case, then ignore my remark.
Substring
Arch doesn't, but as GroovyArcade is based on Arch Linux and I made the updates respect the Arch way, so it's just a matter of adding the repo then you'll have GM. This repo also has a patched SDL2 for KMS modeswitching + 15kHz kernel. So, if you JUST want GM, then add this repo as last, after the offical ones. Otherwise, add it as the first possible repo. I can provide further assistance for the pacman.conf edits
