Author Topic: Ati Radeon Hd 4350  (Read 1836 times)
roccias
  • Last login:August 18, 2023, 08:44:09 am
Ati Radeon Hd 4350
« on: August 01, 2023, 03:30:28 pm »
Hi everyone.  I have the 0.171 version of groovymame with Windows 7 64bit and everything works perfectly. However, now I've decided to update everything to the new version of Groovymame and I wanted to know if this card is still valid (I'd go to emulate the same games with the addition of a couple) and if Windows 7 64 bit is also fine or do you recommend me to buy a new video card ? Thanks
buttersoft
  • Last login:Today at 04:58:45 am
  • Is running at 15kHz
Re: Ati Radeon Hd 4350
« Reply #1 on: August 02, 2023, 07:21:49 am »
- Download CRT Emudriver & CRT Tools 2.0 beta 15 (Catalyst 12.6) for Windows 7/8/10 64-bits
                 Desktop: AMD Radeon™ HD 2000, HD 3000, HD 4000 series
that's from the download page. your Radeon HD 4350 will still work. It does lack EDID emulation however, which is nice to have - you can read about it at section h) of this guide - https://www.aussiearcade.com/topic/76809-a-guide-to-connecting-your-windows-pc-to-an-sd-crt-tv-pvm-or-arcade-monitor/
roccias
« Reply #2 on: August 02, 2023, 09:21:05 am »
Thank you for your answer.  I didn't know anything about the EDID function and its function to save the monitor as well. I think I will buy a 5450 hd since it is cheap and there is also a guide for its configuration.
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
« Reply #3 on: August 03, 2023, 02:38:13 am »
HD4xxx series is legacy. Since series HD5xxx is cheap is better to upgrade, especially if You planning upgrade to Windows 10 for example.
roccias
« Reply #4 on: August 03, 2023, 04:11:56 am »
Thank you
